Old Mar 29th, 2004, 06:55 PM   #1 (permalink)
AznGunner
Question Please help!...my s13 reeks of gas with a full tank!!
The scenario is that after I changed the fuel pump....the smell of gas has been seeping into the cabin. I've replaced the O-ring as well as the gasket that is part of the fuel pump door. Each time I fill the tank up, my car smells like a gas tank. When I run the tank down though, the odors seem to go away....has anybody else seen this problem.....what else could be causing this problem?
AznGunner is offline   Reply With Quote
Old Mar 29th, 2004, 08:20 PM   #2 (permalink)
zlr101
Nissan Fanatic
zlr101's Avatar
Send a message via AIM to zlr101
I know my dad had the same problem not with a 240 but, it was a crack where the filler hose went into the tank.
zlr101 is offline   Reply With Quote
Old Mar 29th, 2004, 08:25 PM   #3 (permalink)
93blackSER
S13 fanatic
93blackSER's Avatar
when you changed the pump, did you use permatex to seal the cover back on? you could have gas sloshing around and getting into your trunk when it's full. that would explain why it goes away when you get lower on gas.
1989 S13 240sx
93blackSER is offline   Reply With Quote
Old Mar 29th, 2004, 10:38 PM   #4 (permalink)
AznGunner
What is permatex?? And where can I buy?
Old Mar 29th, 2004, 10:46 PM   #5 (permalink)
HondaHater
Banned
HondaHater's Avatar
Send a message via AIM to HondaHater Send a message via Yahoo to HondaHater
a lighter helps.
HondaHater is offline   Reply With Quote
Old Mar 29th, 2004, 10:49 PM   #6 (permalink)
uno
uno's Avatar
Originally Posted by HondaHater
a lighter helps.
lol oh frig,i hope you mean a Lighter gas tank LOL
seriously, just don't fill up til you get the problem fixed, i always run 1/2 tank and below , full tank of gas=too much weight
Also make sure you got the two hoses put back on securely and all the way. I just changed mine and i had a problem with the two hoses coming outta the gas tank.
uno is offline   Reply With Quote
Old Mar 29th, 2004, 11:42 PM   #7 (permalink)
Joel
Pivot 180
Joel's Avatar
yeah those hoses get old and split. Put the oring i the sun for an hour or two to dry it out and shrink it back to correct size.
SilviaWA
1992 180SX: cwest, vertex, wise, pivot, gemax, embleton, kyb, blitz, whiteline
Joel is offline   Reply With Quote
Old Mar 29th, 2004, 11:55 PM   #8 (permalink)
HondaHater
Banned
HondaHater's Avatar
i did, that's if you wanna get rid of the problem
Old Mar 30th, 2004, 07:32 AM   #9 (permalink)
AznGunner
Question
I appreciate the suggestions so far.....I will try to look at the hoses and see if they have any problems with them. One question though...how do I gain access to those hoses. I can see them from the fuel pump door but from the suggestions, it seems that I need to look at the other end of the hoses.....is there something I need to remove.......currently there's a panel blocking me.
Old Sep 23rd, 2006, 07:41 PM   #10 (permalink)
jboyle
Angry Pathfinder Gas tank
Yes I have the same problem with my 2000 Pathfinder. The fuel filter pipe was defective and caused the gas to link out when the tank wa full. When I tool it to be repaired the was a 2 month back order for the part. So there must be a big problem with a lot of Nissian's gas tank. I would think there should be a recall before someone gets killed.
jboyle is offline   Reply With Quote
98 SE-R runs out of gas at 1/4 tank! Help! Gorilla Salad SR-Series Engines (DE/VE) 3 May 5th, 2006 03:41 PM
gas tank buzz deenice2k B13 91-94 chassis 20 Jul 17th, 2004 12:10 AM
Oh, another thing... gas tank... nlub13 B13 91-94 chassis 0 Feb 19th, 2004 02:56 PM
service engine light= gas tank problem?? soiledxdesire B14 95-99 chassis 4 May 23rd, 2003 11:29 AM
Lever won't open gas tank.. iron tomm B14 95-99 chassis 8 May 5th, 2003 11:00 PM
