Old Oct 23rd, 2003, 11:25 AM   #1 (permalink)
240aboveall
Engine stumbles in 2nd and 3rd gear when cold
I just started to have this problem: When the car is still warming up and I shift into 2nd or 3rd I loose power when I hit the gas. The car jerks back and the engine stumbles. This only happens for a minute or two. Once the car is warmed up it is fine. It doesn't happen in 1st gear at all. Just second or third. It's almost like I'm not letting the clutch out when I shift but I am. I've done a search for this and came up with a few things to check such as the EGR valve. I've recently removed the AIV valve and this doesn't seem to help. Anyone have any ideas? I also just replaced the Fuel Filter.
240aboveall is offline   Reply With Quote
Old Oct 23rd, 2003, 02:14 PM   #2 (permalink)
DOHC240sxBadBoy
DOHC240sxBadBoy's Avatar
Send a message via AIM to DOHC240sxBadBoy Send a message via Yahoo to DOHC240sxBadBoy
Mine was doing the same thing when it was hot though...then the clutch went out.
Let's Roll!
1993 Nissan SE 240sx DOHC w/ Super HICAS
DOHC240sxBadBoy is offline   Reply With Quote
Old Oct 23rd, 2003, 04:07 PM   #3 (permalink)
drift240sxdragqueen
05-06 NF FF CHAMPION!
drift240sxdragqueen's Avatar
Send a message via AIM to drift240sxdragqueen
let ur car warm up about 2 mins before you go
Originally Posted by Dave2k2
And the rest of you bitches who do nothing but lick each others anus's and high five your retarded flame posts can all go suck a dick, I'm done with this cracker forum.
drift240sxdragqueen is offline   Reply With Quote
Old Oct 23rd, 2003, 07:38 PM   #4 (permalink)
Kelso
so close to turbo...
Send a message via AIM to Kelso
im having a similar problem.....mine is mainly 1st and 2nd though...it like jerks back and forth and i changed my fuel filter....still does it like i never changed anything....so shitty...somebody help us both
Rules:
1)Search – search, search, search. The search button is in the header of EVERY page loaded on NissanForums.com. Search is the third link in from the right on the header. Please use it before you post. Even though this forum is relatively new there is a lot of good information in the database of previous posts. You might find that your question has already been discussed at length and answered.
Kelso is offline   Reply With Quote
Old Oct 24th, 2003, 02:23 PM   #5 (permalink)
DOHC240sxBadBoy
Check your fuel injectors, maybe fuel pump too??, timing or just take it down to tune-up master if there is one in your area and have it tuned. GL!
Let's Roll!
Old Jan 11th, 2004, 03:23 AM   #6 (permalink)
sgo912
same problem...just posted in another thread
I can't seem to accelerate using the 2nd and 3rd gears....only the 1st gear seems fine for acceleration.
What seems to be the problem? When I press the accelerator on the 2nd gear, it just reaches a certain rpm then fails to accelerate. Weird.
sgo912 is offline   Reply With Quote
Old Jan 11th, 2004, 10:19 AM   #7 (permalink)
93blackSER
S13 fanatic
93blackSER's Avatar
hey, stupid noob, dont open up old threads.
1989 S13 240sx
93blackSER is offline   Reply With Quote
Old Jan 11th, 2004, 12:12 PM   #8 (permalink)
drift240sxdragqueen
at least he's using the search button, rather that then make stupid threads... props to u botha man
Old Jan 11th, 2004, 05:31 PM   #9 (permalink)
93blackSER
S13 fanatic
93blackSER's Avatar
i dont think he searched. i think he just read really far into the old threads.
1989 S13 240sx
Old Jan 11th, 2004, 06:26 PM   #10 (permalink)
drift240sxdragqueen
hmmm yea that sounds right, wut would he have used to search for this thread anyways... well at least he is reading... =P
Old Jan 22nd, 2004, 04:28 PM   #11 (permalink)
ghostuss
Send a message via AIM to ghostuss
What you mean you don't know how to use ur 2nd and 3rd? If you mean losing power in 2nd or 3rd once you shift into them, then it's ur shifting problem. Let go of the clutch completely, after you shift into 2 or 3 then accel.
ghostuss is offline   Reply With Quote
Old Jan 22nd, 2004, 04:30 PM   #12 (permalink)
ghostuss
What you mean you can't accelerate in 2nd and 3rd. If you mean losing power in 2nd or 3rd once you shift into them, then it's ur shifting problem. Let go of the clutch completely, after you shift into 2 or 3 then accel. If you drive the 2nd/3rd gear like the 1st gear you are gonna screw up ur tranny or even engine if you readlines.
