Old Aug 5th, 2002, 12:44 AM   #1 (permalink)
SR20Sentra98
Posts: n/a
Any problems with swaping an DET?
My buddy is about to throw a rod in his KA so he ordered a DET a few days ago. We are gonna swap it in soon after we work it through to about 250 or so. He has an S13 coupe and I was wondering what kind of problems that you ran into. Pretty much all that he has for the swap right now is the motor itself. If someone could list any parts that you needed to keep from the KA, and wiring harnesses, where to get them, and any other things to do while we have the motor out and on a stand. Thanks a lot.
Old Aug 10th, 2002, 01:58 AM   #2 (permalink)
SE-Rial killer
Posts: n/a
We just finished up a swap in my buddies S14 well almost just a few more wires to go. Basically while you have it out you might as well do a Clutch and possible a flywheel. Make sure that the oil pan isn't dented or you are in some serious shit! The oil pick up is really close to the pan even if there is a small dent then you will probs. The wiring is pretty straight forward you just have to swap a few wires around and lengthen others. Use the 2.4 T/B for a cheap upgrade. do a fuel pump and filter for sure. Check out www.heavythrottle.com for a good listing of parts and info on the swap. Other then that its quite easy and be ready for the car to be out of commission for almost a month!
Old Aug 24th, 2002, 08:37 PM   #3 (permalink)
t78silvia
Send a message via AIM to t78silvia
I would recommend that you go with an aftermarket fuel/engine management system setup. It will be easier to install than swapping the harnesses, and if you want serious power it's the only way to go. The only down side is that they are pricey, $1100+ i would estimate.
t78silvia is offline   Reply With Quote
Old Sep 2nd, 2002, 02:05 PM   #4 (permalink)
Yellow4g63
Send a message via AIM to Yellow4g63 Send a message via Yahoo to Yellow4g63
If u don't get a front clip then go with a haltech or a TEC II. If u get a front clip all u have to do is extend 6 wires and your done.
90 Tsi with lots of toys
89 240sx maybe it will be fast
Yellow4g63 is offline   Reply With Quote
Old Sep 3rd, 2002, 10:49 AM   #5 (permalink)
t78silvia
if you want to produce serious power, go microtech....i stayed away from the harness mess and am now producing 415whp.
Old Sep 3rd, 2002, 11:01 AM   #6 (permalink)
Yellow4g63
U can make 400hp with the stock ECU too, just need to piggy back it or reprogam it. It's not a too hard to wire it up if u have a front clip.
Old Sep 6th, 2002, 12:41 AM   #7 (permalink)
SE-Rial killer
Posts: n/a
if anyone is looking for an S13 for a perfect DET swap my buddy in WA has one for 1500 bucks!! Just thought I would let you know... BY the way you can get a decently programmed ecu for around 500 bucks and although it doesn't have full tuning capabilities like the Haltech and SDS system from Japan it still makes a signifcant difference in performance!
B13SE Suspension AFTER DET swap enuf? eugenefl Suspension & Brakes 4 Mar 25th, 2004 03:51 AM
RWD CAS (crank angle sensor) on a FWD/AWD DET javierb14 SR-Series Engines (DE/VE) 2 Sep 7th, 2003 04:41 AM
starting problems dono200sx GA16DE 1.6L Engine 7 Jul 16th, 2003 09:13 PM
EASY DET swap......possible? BIGBULS Forced Induction & Nitrous Oxide 10 Dec 21st, 2002 02:02 AM
Common Problems with Det swap into se-r sr21lbmonster SR-Series Engines (DE/VE) 0 Jun 20th, 2002 09:22 AM
