Old Sep 16th, 2003, 12:59 AM   #1 (permalink)
thecollector
S13 water pump
My water pump appears to going bad. Small leak from the bearing area. Is there an interchangeable part or will I have to obtain a direct sr20det s13 water pump?
TheCollector
1993 240sx
Sr20det S13
My never ending creation
thecollector is offline   Reply With Quote
Old Sep 16th, 2003, 02:27 AM   #2 (permalink)
Joel
Pivot 180
Joel's Avatar
i know that the s14 doesnt fit so theres a good chance you need to get a new s13 one. Can you overhaul it though?
SilviaWA
1992 180SX: cwest, vertex, wise, pivot, gemax, embleton, kyb, blitz, whiteline
Joel is offline   Reply With Quote
Old Sep 16th, 2003, 08:47 AM   #3 (permalink)
thecollector
When I had my alternator rebuilt, they gave up and we settled on the closest thing that suprisingly worked. They are the best rebuilders in central Ohio. So, I think I will probably have the same problem with a pump, hoping there is a changeable part, like off a sentra?
TheCollector
1993 240sx
Sr20det S13
Old Nov 22nd, 2003, 02:56 AM   #4 (permalink)
ralphdig
Once it hapen to me, I got a remplacement at a local autoparts, one for a small pickup truck whith a 2.4 Lts engine.
It fit perfectly and a lot cheaper than the original.
ralphdig is offline   Reply With Quote
