Boggin, sputtering..help? - Nissan Forum
post #1 of 8 Old Aug 11th, 2003, 12:15 PM Thread Starter
Send a message via AIM to yomny
I have a 93 240sx and the problem is that it bogs under acceleration, when i accelerate instead of picking up it sort of bogs, it goes but like not with it's full potential, like misfire or sputter. It already replaced the spark plugs and the wires. I also removed the AIV and that whole system thing, the car worked better for a day and then went back to the sputtering. Thanks
Just boost It
yomny is offline
post #2 of 8 Old Aug 11th, 2003, 12:53 PM
Nissan Fanatic
check the fuel filter. Those can make your car run like ass. Go with the Z32 fuel filter while you are at it
nx2000 is offline
post #3 of 8 Old Aug 11th, 2003, 12:58 PM Thread Starter
where can i get it, just go to an auto parts and ask for a what? what year car is it fuel filter. Also to change it i should disconnect the fuel pump fuse, to empty out the lines of gas as much as possible? Thanks
Just boost It
yomny is offline
post #4 of 8 Old Aug 11th, 2003, 01:19 PM
Nissan Fanatic
1990-1996 300zx. I dont know if it is N/A or TT. Maybe eithere works..can't recall. I honestly hav enever chnaged a fuel filter. I am about to though because I am installing a walbro 255lph pump. I would disconnect the fuse if nothing else. You can also catch the gas in a pan and put it into a gas can and re use it....dont know how pratical that is. Does fuel that hits air have nay advers affects on performance/driveability
nx2000 is offline
post #5 of 8 Old Mar 9th, 2006, 02:23 PM
95 240sx
OK heres the run down of mine . WHile driving it will sputter and the whole car with jump . Strangely enough it settles down and goes away . The check engine light is on . Any ideas ? I'm thinking of running some fuel injector cleaner and a tune up to start .
Smack'snissan is offline
post #6 of 8 Old Mar 9th, 2006, 09:05 PM
Sup Mod keeping the peace
rogoman's Avatar
If the 'check engine' light is on, do an ECU code readout. It will most likely help you fix your problem.
rogoman is offline
post #7 of 8 Old Mar 14th, 2006, 05:34 PM
O2 sensor
CHeck engine light was on . Autozone said the EGR the MAS and the O2 were all in alarm . So I did a tune up changed the o2 sensor , but not quite ready for the money to spend on the others . However ! She's running like a dream now ! The O2 sensor must have done the trick , I can even tell a power increase (probably the tuneup ) . Anyway figured I'd post the fix O2 sensor all the way . I'll fix the others just to get the light off .
post #8 of 8 Old Mar 15th, 2006, 04:04 AM
sr20 freek
surfer240sx's Avatar
Send a message via AIM to surfer240sx
while ur workin on it get a pcv valve it stopped my probs and it was only 3 bucks and 5 mins of work
surfer240sx is offline
  Nissan Forum > 240SX/Silvia/S12 200SX > S13 240SX 1989-1994
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
