S13 Drivers Power Window Acting Funny
Hey all,
I'm having a problem with my drivers side window and I hope you can help me out. Sometimes this window will go up and down and sometimes it won't. When it works, it had no trouble. Therefore, I'm assuming that the motor and regulator are still good. I've taken the door panel off and I notice that when I notice that there is a wire harness going from my switch to some black box (about 1" x 1" x 4 "). When I manipulate the plug going into the box, I can usually get the window to go up and down. Therefore, I'm thinking that it's either the plug, the harness, or that black box. What confuses me, however, is that is that the passenger side window can always be controlled from the drivers side door and that utilizes the same harness, plug, and switch. Any thoughts? I'd appreciate any advice. Thank you much.
----Matt
