How-To Article: Replacing the EGR valve on a '91 240sx - Nissan Forum
post #1 of 1 Old Aug 26th, 2011, 01:21 PM Thread Starter
techtalk's Avatar
Happy Friday ladies and gents!
I've recently replaced the EGR valve on a customer's 1991 240sx (the thing was in immaculate condition too!) so I've decided to post up a handy dandy DIY article for you 240 owners and fans
1. Remove the nuts which attach the EGR tube and/or the BP tube to the EGR valve (refer to this 240sx EGR diagram).
2. Unscrew the mounting bolts and remove the heat shield plate from the EGR control valve.
3. Tag and disconnect the EGR vacuum hose(s).
4. Unscrew the mounting bolts and remove the EGR control valve.
To install:
5. Install the EGR valve assembly with mounting bolts (torque retaining bolts EVENLY) to intake manifold location.
6. Connect all vacuum hoses and install the heat shield if so equipped.
7. Connect EGR tube or BP tube to the EGR valve if so equipped.
8. You're done!
techtalk is offline
  Nissan Forum > 240SX/Silvia/S12 200SX > S13 240SX 1989-1994
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
