» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > 240SX/Silvia/S12 200SX > S13 240SX 1989-1994
Old Jun 29th, 2008, 10:11 AM   #1 (permalink)
matt_101
Send a message via MSN to matt_101
High speed wobble
Hello,
Just installed my kyb agx and dropzone lowering springs, the car had a slight high speed wobble before but it is worse now.It was my first strut/spring install so its very possible i made a mistake. The car handles great below about 80-90 km/h and above 110Km/h in between there it shakes violently. Also before the install there was a strange ware pattern on the front tires, i thought it was due to the stock struts being shot but im not sure (the stockers were SHOT!!!!!!!). So what should i do to fix this - do you think i just need a wheel alignment/balance?
Thanks
matt_101 is offline   Reply With Quote
Old Jun 29th, 2008, 10:24 PM   #2 (permalink)
rogoman
Sup Mod keeping the peace
rogoman's Avatar
A wheel alignment/balance would certainly be in order. Also check the suspension for worn bushings and ball joints.
KA-T for life, yo!
rogoman is online now   Reply With Quote
Old Jun 30th, 2008, 12:30 AM   #3 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
Send a message via AIM to trmn8r
yeah definately need an alignment. and a wheel balance. id also check if your tires have fix a flat in it. that would definately mess up your balance at high speeds. do what rogo says. and if you have access to a tire machine. check inside the tires for liquid
Quote of the Day From Our Shop " I think ima gonna drive my little puff down the the lake tommarow and force myself to drown a worm, i recon sooo!"
trmn8r is offline   Reply With Quote
Old Jun 30th, 2008, 06:53 AM   #4 (permalink)
matt_101
UPDATE
I had a wheel alignment done - toe was out in the front a little, still wobbles at high speed. Kept some negative camber So i guess balanceing the two front wheels is the next step...... the front tires are crap - as i said there is a strange wear pattern on the outside edges of both front tires. I am considerign replaceing them - -or buying 4 rims/tires. I have 2 firehawk gt's on the back now, so i'd like to get at least a seaon on them before i buy rims.
Alternativly, i could buy 2 more firehawk gt's for the front and wait til next summer for rims.(rims are a huge priority to me - my turbo system build is)
Do you guys think theres any point in balaceing the fronts (given the wear pattern mentioned above)? IE: will the balceing make the wobble go away or will it still wobble due to the wear. or should i buy new front tires.
Is it likey that the wear pattern is the cause of the wear.
Thanks,
Matt Brown
Old Jun 30th, 2008, 08:52 PM   #5 (permalink)
rogoman
rogoman's Avatar
The abnormal wear pattern was most likely caused by the toe being out of spec. Also check for bent wheels.
If the tires are shot, don't waste your money on balancing them, buy new ones.
KA-T for life, yo!
Old Jul 3rd, 2008, 06:42 AM   #6 (permalink)
matt_101
OKay....new tires installed and balanced on the front - wobble is gone. However....... i never mentioned this before but the car was pulling to the right (passengeres side). It does this much less now with the new tires but it does still do it. My concern is that whatever is causeing the car to pull to the right is the cause of the abnormal tire wear. any idea what could still be causeing this?
Old Jul 3rd, 2008, 10:08 AM   #7 (permalink)
Omerta11023
Omerta11023's Avatar
Send a message via AIM to Omerta11023
do you?
do you have aftermarket tension rods?
if so one side isnt adjusted exactly to the other side.
happened to me too then i counted threads when adjusting on both sides and the pull dissapeered.
Tomei SR's make me drool.
Omerta11023 is offline   Reply With Quote
Old Jul 3rd, 2008, 10:28 AM   #8 (permalink)
Asleep
Super Mod - ALL the time!
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
check the bushings in the tension rods for wear. the rubber could be shot.
Asleep is offline   Reply With Quote
Old Jul 3rd, 2008, 04:18 PM   #9 (permalink)
rogoman
rogoman's Avatar
Don't run too much negative camber otherwise it'll wear out the tires quickly and could be causing the pull to the right. Make sure the toe-in is correct.
KA-T for life, yo!
Old Jul 3rd, 2008, 06:20 PM   #10 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
your supposed to do an alignment with the new tires on. now the alignment your just did was set up for the old worn tires. id do an alignment again
Old Jul 3rd, 2008, 08:44 PM   #11 (permalink)
matt_101
The tension rob bushings are not in the best of shape - im gonna check the entire suspension system over this weekend while i put my new rotors and pads on. I'll post up when i find the cause. If the negative camber is the problem then i'll live with it - cause the car handles like its on rails now and it body rolled and wheel hopped everywhere all the time before lol also..... Do i realy need another alignment? even though the tires are the exact same size as the old ones
:S?
Thank you all very much for you input - i dunno what i'd do without forums. lol
Old Jul 3rd, 2008, 10:59 PM   #12 (permalink)
Asleep
Asleep's Avatar
new tires - even the same size - are a different size when worn. especially if you have outer edge wear, the tire puts a different type of stress on the suspension which will affect the alignment.
Old Jul 6th, 2008, 09:08 AM   #13 (permalink)
matt_101
Just did my brakes on all 4 corners (pads and rotors).... wobble is gone completely and the car tracks straight. Thanks very much for all your help - im going to get another alignment and replace the tension rods and bushings for good measure.
Old Jul 16th, 2008, 04:02 AM   #14 (permalink)
racersonly2004
Send a message via AIM to racersonly2004 Send a message via Yahoo to racersonly2004
good job make sure to get the alignment after you change your bushings and other suspenssion components. doing this in reaverse could cause the alignment to be off. also sheck for play in your ball joints tie rods and wheel bearings. if the wear is excessive you should also change these before an alignment.
racersonly2004 is offline   Reply With Quote
Old Jul 16th, 2008, 05:53 AM   #15 (permalink)
OchnofConcrete
Nissan Fanatic
OchnofConcrete's Avatar
Send a message via AIM to OchnofConcrete
Asleep or Rogo, could yall sticky this thread? it's got good basic suspension info in it and i'd hate for it to get lost in the back. or something... dunno how yall go about keeping good info from gettin lost in the shuffle. be even cooler if someone put down some real good indepth stuff for guys that want to get into adjusting their camber, caster, and toe.
never had money for suspension sides stock, but i'd love to have some good info to go back to for my own learning process down the road.
damn, i'm really gettin impatient waiting to get my 240 runnin.
OchnofConcrete is offline   Reply With Quote
