To perform a 300zx rear brake upgrade, I know I need the backing plates from a 300zx for the e-brake. On the inner side of those plates, there is a big threaded stud which I don't know where it links up to.
does somebody know?
the threaded stud goes throught the upper part of the knuckle if you use your finger youll find the hole already there on the knuckle. you might have to dremil it just a little for the stud to go through. rear brake swap is practically plug and play just need to fiddle with some things.
__________________ Quote of the Day From Our Shop "Quick, ill wiggle it while you tug on it"
So u saying it is easy to do rear 300zx swap on 240sx? What about the e-brake? That website, that everybody refer to, does not really explain what and how exactly to deal with e-brake problem. Is there some one in here who have done the swap (him/her)self and can help me?
you have to use the r33 rear e brake cables and those will work fine
Do i need to get rear up alluminum uprights from 300zx too? to get it all fit ? do u know all i need to get to do rear conversion 300zx on my 95 240sx se (5lug)?
no its not necessary. of course youll need 5 lug rear conversion
where do I exactly connect the R33 E-brake cables on the caliper or does it go on the uprights/hub? Because I didnt c any holes for the E-brake cables on calipers :/
ok i c ... so it goes in the hub and the hub kinda works like a drum brake it has brake shoes inside for the e-brake right? calipers have nothing to do with the e-brake correrct ??
so all i need than is:
300zx calipers + pads
300zx rotors
aftermarket brake line to fit my calipers
r33 e-brake cables
i already have sum kinda bridgestone aftermarket brake lines. Not sure they will fit rear calipers, even thou they do work with front 300zx calipers. They must fit rear too right?
dude 240sx dont have drum e-brakes .... wow that was a waste of money, so wtf r33 e brake cables would be useless, wut kinda hud do i need, like from 300zx uprights? WUT do i do about e brake???
