Old Dec 22nd, 2007, 08:15 PM   #1 (permalink)
nikeboy504
have to pump the gas pedal on a fuel injected car to get it started
ok. i have a 1989 nissan 240sx and have had this problem for a while and have replaced many things on it to fix but nothing seems to help. when i turn it over it sound like it is not hitting but the spark plugs and wires are all good. i have replaced the fuel pump several times and the fuel filter, i got used injectors to put on it and that didnt work. i kinda checked the fuel injector by tying them down with zip ties and turning the ignition on but the injectors didnt spray. i dont know if they are supposed to, but i had my friend turn the egine over and then it started to spray a little bit.
if you have any suggestions on what might be my problem i would appreciate it. thanks
nikeboy504 is offline   Reply With Quote
Old Dec 22nd, 2007, 08:56 PM   #2 (permalink)
Asleep
Super Mod - ALL the time!
Asleep's Avatar
Send a message via AIM to Asleep Send a message via Yahoo to Asleep
are you sure your fuel filter and pump are working?
do you hear your pump coming on when you turn the key to on?
Nissan Moderators needed
contact Sassan @ www.SUPERNISSANS.net
http://www.cardomain.com/id/our rides
Asleep is offline   Reply With Quote
Old Dec 22nd, 2007, 09:01 PM   #3 (permalink)
nikeboy504
i have recently changed the fuel filter and pump, and yes the pump comes on every time i turn the key. it will start but i have to pump the gas every time.
Old Dec 23rd, 2007, 09:42 PM   #4 (permalink)
rogoman
Keeping the peace
rogoman's Avatar
If the motor is hard to start, here's a few possibilities:
- sticking EGR valve
- low fuel pressure
- weak spark
- dirty IACV
- bad air regulator
Old Dec 23rd, 2007, 09:55 PM   #5 (permalink)
Asleep
Asleep's Avatar
according to the fsm, if the gas pedal has to be moved for the engine to start, the iacv is bad.
Old Dec 23rd, 2007, 09:56 PM   #6 (permalink)
nikeboy504
how can i tell if the EGR is stick
Old Dec 23rd, 2007, 10:18 PM   #7 (permalink)
Asleep
Asleep's Avatar
easy. underneath the egr is a valve. its actually inside the egr but you can get to it from the bottom.
run the engine, if you can get it to start, then depress that valve. if it doesnt move, the egr is stuck. if it does move, the engine should stall.
91 NX1600 runs for a week, dies then wont start for 2 days...intermitent pattern triplefour B13 91-94 chassis 5 Sep 2nd, 2008 10:27 PM
95 Altima - stalling / idling issue dstanek U13 1993-1997 Altima 19 Aug 4th, 2008 10:09 PM
fuel pump problem SubaruBlue200sx Forced Induction & Nitrous Oxide 2 Aug 25th, 2007 01:06 AM
How to replace a 93 nissan nx 1600 fuel pump cesemj GA16DE 1.6L Engine 3 Sep 25th, 2004 11:33 PM
Injectors or Fuel Pump? tzamler New Member Forum 2 Nov 7th, 2003 05:02 PM
