Old May 17th, 2007, 12:04 PM   #1 (permalink)
nochez
240SX fuel trouble
My son just bought a 1989 240SX after driving it it smells like gas under the hood.
we already replaced one fuel injector because the cap was broke and replace all o-rings for the rest of the fuel injectors does any body have any ideas what else to check or how do you adjust the fuel because it might be running to rich.
nochez is offline   Reply With Quote
Old May 18th, 2007, 08:13 AM   #2 (permalink)
jeffwubze
did you guys replace the fuel filter and all the hoses?there might be a leak or loose
jeffwubze is offline   Reply With Quote
Old May 18th, 2007, 02:06 PM   #3 (permalink)
rogoman
Super Moderator
rogoman's Avatar
The fuel pressure is not adjustable. To check the fuel pressure, tee-in a tempoarary fuel pressure gauge at the output side of the fuel filter. The readings at idle should be as follows:
- with vacuum hose connected to the fuel pressure regulator: 33 psi
- with vacuum hose disconnected from the fuel pressure regulator: 43 psi
Old May 18th, 2007, 05:23 PM   #4 (permalink)
nochez
Thanks I'll check the hoses and fuel filter
Old May 19th, 2007, 08:34 PM   #5 (permalink)
nochez
Its leaking on top of fuel injector we already replaced orings
Old May 21st, 2007, 10:36 PM   #6 (permalink)
180SX-X
Nissan Addict
180SX-X's Avatar
check the fuel rail, maybe its cracked...
180SX-X is offline   Reply With Quote
Old May 22nd, 2007, 04:06 AM   #7 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
If you are leaking at the top of the injector. Try swapping injectors between one CYL and the other. I have had an injector leak at one spot and not another. Change the Orings. If you have a parts store called Orileys they have the best deal and best oring replacement kits. $2 something a set.
Here is a link that might help
http://www.nissanforums.com/s13-240s...injectors.html
Trippen
"I reject your reality and substitute one of my own" Adam-Myth Busters
" I dont give Frequent Flyer miles for Guilt Trips"
89 240SX SE FB -KYB AGX w/RS-R race Springs. [
95 240sx se KA-T Borded .20 over JWT ECU, Z32 MAF, Arias Pistons, Eagle Rods, 50 trim T3/T4 turbo, 50lb MSD, J30 LSD, Custom Drive shaft,D21 flywheel,PLX-R500 and TurboXS Knock lite keeping tabs on everything
fastback-hatch-rattle-fix-how-too.html
Trippen is offline   Reply With Quote
OBD II Code Chart no1see2me QG18 1.8L Engine 7 Oct 21st, 2006 12:36 PM
The KA Turbo Thread bridrive55 General 240SX/Silvia/S12 200SX 26 Aug 1st, 2006 09:24 PM
Fuel Filter on GA16DE, can't remove... thestunts200sx GA16DE 1.6L Engine 9 Feb 5th, 2006 03:58 PM
Taiwanese...? Jeff Dallas Nissan Enthusiasts 9 Dec 8th, 2004 07:55 AM
240sx fuel injection probs gets S13 240SX 1989-1994 1 Jan 16th, 2003 04:23 PM
