Old Apr 23rd, 2007, 10:18 AM   #1 (permalink)
exkuisiteone
exkuisiteone's Avatar
Send a message via Yahoo to exkuisiteone
Lightbulb 98 240 engine swap in an 89 240. how similar are they?
I am currently swapping an 98 ka motor into an 89. I put the trans and motor together and when i turn the crank there is a sound in the bell housing!! are these motors identical?
They look to be the same to myself but will the transmission from the 89 go on the 98 motor without any mods? SOMEBODY PLEASE HELP!!! The noise sound to me like the input shaft that goes into the torque converter is not all the way in but the trans and motor are bolted up tight. I used the same input shaft from the 98 and it went right into the 89 trans with no problem. I know the noise is not normal, i pulled it off and looked and put it back on and still the same thing. There is nothing wrong with the 89 trans but the 98 slips.
any help would be greatly appreciated guys!
"Givin the Sentra Hell 24/7 is my job"
"wanna earn a dolla while your down there?"
exkuisiteone is offline   Reply With Quote
Old Apr 23rd, 2007, 09:13 PM   #2 (permalink)
rogoman
Super Moderator
rogoman's Avatar
Does the '98 motor have the proper crankshaft pilot bushing for an A/T?
Old Apr 24th, 2007, 02:30 PM   #3 (permalink)
exkuisiteone
yes both are auto motors.......
i got them together and in the car and I am now wiring them p. BUT the starter was the noise i was hearing. It was hitting the flywheel. i tried both starters and got the same noise. HELP!!!!!
Old Apr 30th, 2007, 08:44 AM   #4 (permalink)
rogoman
Super Moderator
rogoman's Avatar
Both starter and both torque plates (flywheels) should be the same for both engines. You need to remove the A/T along with the torque convertor. Now do a test fit of the starter to the engine block and observe the clearance between the torque plate teeth, front and back, and the starter housing.
There is a reinforcement plate that bolts on to the center of the torque plate on the outside; it may instead be between the crankshaft flange and the torque plate; if so, it'll cause interfenence with the starter.
Old May 1st, 2007, 12:03 AM   #5 (permalink)
exkuisiteone
sweeeet i got it done now. just grinded down the starter...
Old May 1st, 2007, 12:55 AM   #6 (permalink)
180hero
lol sorry to intervine with no real info... but that just sucks balls... but in all seriousness... how much did u get that 98 ka for??
180hero is offline   Reply With Quote
Old May 1st, 2007, 06:10 PM   #7 (permalink)
BlackMage
Send a message via AIM to BlackMage
Don't forget your P/S, A/C and tech and a few other random things will have issues between the change from SOHC to DOHC. It's just like doing an SR swap into an 89
BlackMage is offline   Reply With Quote
Old May 1st, 2007, 08:16 PM   #8 (permalink)
exkuisiteone
i got the motor for free!!! trans and all! all it needed was a timing chain and guides.
that's it. I have a friend that works at nissan and hehas 3 240's with the sylvia conversion. other than that it runs GREAT
Old May 2nd, 2007, 11:14 PM   #9 (permalink)
180SX-X
Nissan Addict
180SX-X's Avatar
you grinded down the starter?!?
A wise man once told me, 'If you drive to win, you're digging a new hole, but if you drive for passion, its already been dug up.'
If you're a driving person, this saying has meaning..
180SX-X is offline   Reply With Quote
Old May 8th, 2007, 11:43 AM   #10 (permalink)
exkuisiteone
ya the lip on the outer side towards the trans just a hair!!!!! not much. don't know why it was hitting but it runs and drives fine now
need a good reliable place to get a Z tt engine swap in WI or near chicago. apezsalezz Z32 Chassis 300ZX 1 Oct 15th, 2006 11:15 PM
Cleaning the Engine Bay – For a Newbie by a Newbie aperumal Car Care 0 Sep 24th, 2006 10:26 AM
The KA Turbo Thread bridrive55 General 240SX/Silvia/S12 200SX 26 Aug 1st, 2006 09:24 PM
01 Engine Swap. What equipment do I need? Str8Leg Pathfinder 6 Jun 22nd, 2006 04:34 PM
Nizmodores RB Swap Thread! Nizmodore General 240SX/Silvia/S12 200SX 3 Apr 29th, 2004 08:10 AM
