Old Apr 5th, 2007, 01:25 PM   #1 (permalink)
nc89240
engine issues
I have a 89 240 with a bone stock KA24E. I am having some major problems, the car wont idle and when it does run it wont accelerate past 2500rpms. Distributor housing is broken so it might be losing its timing, I am replacing it this weekend so any other help would be great. Thanks ahead of time.
nc89240
nc89240 is offline   Reply With Quote
Old Apr 5th, 2007, 01:55 PM   #2 (permalink)
Nismo240
i'm an asshole
Nismo240's Avatar
you probably have a bad MAF if it won't go past 2500rpm's.
Nismo240 is offline   Reply With Quote
Old Apr 16th, 2007, 10:52 AM   #3 (permalink)
nc89240
replaced distributor over the weekend now the damn thing wont start at all... will check the maf later today thanks for the help on that. the distributor i got must be bad, going to try and swap the case out, because I know that the other one is good...any other advice would be appreciated.
Old Apr 17th, 2007, 03:30 PM   #4 (permalink)
rogoman
Super Moderator
rogoman's Avatar
The ignition timing may be off. How did you install the dist?
Old Apr 17th, 2007, 11:24 PM   #5 (permalink)
180SX-X
Nissan Addict
180SX-X's Avatar
its probably ass backwards. people make mistakes. like when i wired my car plugs ass backwards, that was not fun. if its not the dist, or the maf, check vacuum, check throttle and cable/linkage(yes, i am serious, long story), and also your grounds(yes, i said grounds, they are actually there for something!!!)...
A wise man once told me, 'If you drive to win, you're digging a new hole, but if you drive for passion, its already been dug up.'
If you're a driving person, this saying has meaning..
180SX-X is offline   Reply With Quote
Old Apr 23rd, 2007, 11:16 AM   #6 (permalink)
nc89240
thanks guys havent had a chance to work on it lately will let you know what i find out. Thanks for all the advice.
2003 Altima 2.5s engine DESTROYED from loose Power Valve Screws. lax26grad L31 2002 - 2006 21 Mar 12th, 2007 01:57 PM
Engine Knock on Mexican built GA16DE Sentras Pablo14 GA16DE 1.6L Engine 44 Jul 5th, 2006 10:16 PM
Need Advice on Engine repair meesh L30 1998-2001 Altima 7 Nov 12th, 2005 01:21 AM
Engine Coil Issues - Check Engine Soon trianec A33 2000-2003 Chassis 5 Jan 15th, 2005 08:22 AM
Converting a VG30 engine to Fuel Injection MrBadExample Truck & SUV 1 May 15th, 2004 10:17 AM
