Old Apr 3rd, 2007, 09:23 PM   #1 (permalink)
Brentonium
Brentonium's Avatar
Smile First Car = First Problems
I just got a 1992 Nissan 240SX for my birthday. It ran fine for about a week and then I noticed the tailights would never turn off. I of course noticed too late and Mr. Battery dies and @ the same time alternator belt splits. I recharge the battery, still tailight thing going on, so I unplug. Now water pump go very bad because previous owner does not screw all screws in. I purchase new pump for $50 plan to install tomorrow morning.
I still need a little help with the brake lights.
BTW This is KA24 motor.(I need this car to get me from Home----> Job so I can buy SR20DET eventually)
Brentonium is offline   Reply With Quote
Old Apr 4th, 2007, 03:45 PM   #2 (permalink)
rogoman
Super Moderator
rogoman's Avatar
Check the brake light switch at the top of the brake pedal; it might be shorted.
Oh by the way, keep the text in BLACK like everybody else!
Old Apr 4th, 2007, 04:01 PM   #3 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
We Dont always have to conform to color and reason.....
Brake light switch is my guess as well
Trippen
"I reject your reality and substitute one of my own" Adam-Myth Busters
" I dont give Frequent Flyer miles for Guilt Trips"
89 240SX SE FB -KYB AGX w/RS-R race Springs. [
95 240sx se KA-T Borded .20 over JWT ECU, Z32 MAF, Arias Pistons, Eagle Rods, 50 trim T3/T4 turbo, 50lb MSD, J30 LSD, Custom Drive shaft,D21 flywheel,PLX-R500 and TurboXS Knock lite keeping tabs on everything
fastback-hatch-rattle-fix-how-too.html
Trippen is offline   Reply With Quote
Old Apr 6th, 2007, 01:17 PM   #4 (permalink)
Brentonium
Brentonium's Avatar
Checked, Replaced, What's Going on?
I checkedand the brake switch was very hot, so I purchased new one for $6 and it's an incredible pain to replace. I'm not sure that I got it in there right and the lights still won't shut off. I just unplug the switch everytime I turn the car off.
Old Apr 7th, 2007, 01:10 AM   #5 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
Is it the brake Lights or the running lights???? With someone behind the car and you press the peddle do the lights come on(Peddle pressed) and off? IF so the switch is good. If you see a light on then a brighter one comes on then your brake switch is ok start looking for a bad light switch. I am sorry if this sounds very simplistic but your problem with out a good amount of information could lead us to telling you to go in the wrong direction.
Trippen
Old Apr 7th, 2007, 05:12 PM   #6 (permalink)
Brentonium
Brentonium's Avatar
Smile No More Problems
I got it fixed, I had to replace the brake switch with the little black button on it and the rubber thing that presses in. Thanks for your help. I also found out that my power steering was leaking. $126 to replace the hose. No problems anymore. I can't wait to start on my engine swap, but first I'll be putting coilovers, wheels, tires, brakes, and some other stuff for safety. My father won't let me swap engine until I upgrade brakes and suspension first.
I sign my name in C R A Y O L A
Old Apr 7th, 2007, 05:18 PM   #7 (permalink)
Nismo240
i'm an asshole
Nismo240's Avatar
Originally Posted by Brentonium
First I'll be putting coilovers, wheels, tires, brakes, and some other stuff for safety. My father won't let me swap engine until I upgrade brakes and suspension first.
thats smart, most people over look these components when making high horsepower cars. i wish most people would upgrade these first, you can't expect stock brakes to stop 600HP.
Nismo240 is offline   Reply With Quote
Old Apr 10th, 2007, 03:08 PM   #8 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
Gotta have suspension to hold the power. And the brakes to hold that power back...Your father is a smart man.
Trippen
Old Apr 13th, 2007, 11:47 PM   #9 (permalink)
Brentonium
Brentonium's Avatar
Smile HKS Hipermax
I just got a good job and I will be ordering the HKS Hipermax Coilovers sometime before summer.
Old Apr 14th, 2007, 09:45 PM   #10 (permalink)
CrypticScotpio
yo you got it easy, i bought my 240sx with a shot motor, alternator and severly cracked frame i dropped over 1800 into her before i could crank the engine and go around the block. and yea ur old man is smart, ive seen bad accedents from morons doing a sr20 but forgetting about good ceramic brakes to stop at the lights.
CrypticScotpio is offline   Reply With Quote
Old Apr 14th, 2007, 09:49 PM   #11 (permalink)
trmn8r
I'm an asshole #2
trmn8r's Avatar
Send a message via AIM to trmn8r
i put my sr in 2 oh hold on 2007 oh dats 3 years ago and im still alive. "ceramic brakes, where?". ceramic brakes have to get up to temperature to start working at there full potential. all you need are some semi metalics.
Quote of the Day From Our Shop "Quick, ill wiggle it while you tug on it"
trmn8r is offline   Reply With Quote
Old Apr 14th, 2007, 10:10 PM   #12 (permalink)
CrypticScotpio
yea but your probly a good driver.... ever see a 16 yr old kid that just learning how to drive with a sr20 at his finger tips... only saying this cause i was in the same boat with an integra with a vtec swap on my 16th... only lasted me 3 months before a nice t-bone incedent with a lincoln navigator... im still stickin to my story that the navigator fell from the sky infront of me
Old Apr 15th, 2007, 03:02 PM   #13 (permalink)
DriftX
DriftX's Avatar
HKS coilovers? at 16? Someone is selling illegal drugs or something to afford that shiz.
89' 240sx
RB20DET > KA24E
DriftX is offline   Reply With Quote
Old Apr 16th, 2007, 11:17 PM   #14 (permalink)
Brentonium
Brentonium's Avatar
Talking
Connections boys and girls... connections. My father has alot of sponsers for his car. Porsche 911, rebuild engine, twin turbo 960hp nothing left untouched. He'll be showing his car of and probably some of his new gadgets at HIN in FL and then in ATL in Nopi coming up. It's bright yellow convertible.
Weird power loss/smoking/oil leak problems kaizoku GA16DE 1.6L Engine 10 Mar 20th, 2008 01:51 AM
Please help 2!!!!!!!!! jeffwubze S13 240SX 1989-1994 78 May 18th, 2007 07:50 AM
Car Problems Specv_Tuner QR25 2.5L Engine 2 Nov 28th, 2006 10:14 AM
Help with driveability problems johnand GA16DE 1.6L Engine 14 Oct 2nd, 2005 10:51 AM
help with my 94 maybe Fuel leak? /bose/bad idle at times/ac heat? And handling? DonaldHays J30 1989-1994 Chassis 3 Aug 16th, 2005 07:56 AM
