Old Mar 28th, 2007, 10:28 AM   #1 (permalink)
jcorbi82
A Coolant Leak issue
Well, it seems the car has found anotuerh issue to hit me with! As far as I can tell, a hose developed a leak and I need to change it. I say this because it seems to be coming from a particular hose, and I can see coolant dripping from it. I first noticed a small pool of coolant on the ground after turning the car off, a few drops, and noticed a slow drip. After turning on the AC full blast for the first time this year, the temp gauge shot up and I had to park the car... Steam coming from passenger side area by the hoses, and when I opened the radiator cap the steam came from there. I added water (no coolant or 50/50 mix) as much i could, and adding water displaced the steam. This morning, I filled it back up as told by looking at the radiator level under acceleration and put the cap back on, but it is still leaking from the hose.
So, I hope to get the hoses replaced soon. Does it sometimes happen that hoses spring a leak, and this occurs?? Thanks.
jcorbi82 is offline   Reply With Quote
Old Mar 28th, 2007, 08:07 PM   #2 (permalink)
rogoman
Super Moderator
rogoman's Avatar
Yes, it can happen especially when the hoses are old. Your slow drip turns into a raging pisser when the motor fully warms up; you'll lose the coolant in a matter of a few miles of running.
Coolant leak question NPath Pathfinder 0 Feb 20th, 2006 11:14 PM
Coolant leak? coolant in exhaust? lg2005 B14 95-99 chassis 8 Jan 5th, 2006 04:22 PM
86 N/a coolant leak DBSS_Gohan Z31 300ZX(T) 23 Sep 30th, 2004 09:13 PM
coolant leak 91SERHondaKiller SR-Series Engines (DE/VE) 8 Apr 5th, 2004 09:20 PM
Coolant Leak....Please help! Mazoku B14 95-99 chassis 3 Dec 30th, 2002 07:52 PM
