240sx fuel injection probs
i own a 90 nissan 240 sx ka24e engine
what would cause very weak voltage to the injectors?
each injector is recieving 12 volts at the positive side of the harness.
the problem seems to lie on the gound side of the injector circuit
(when i use a noid light the noid light up very weakly when trying to start car.)
using a mitchel wiring diagram i have checked all ecm grounds, all chassis grounds. every related circuit i could and all checks out normally.
in a nut shell everything that should be checks out ok (mass air, throttle position sensor, grounds etc.) the only issue if that the injector signal is very weak(exact same condition for each injector harness)
the history of the cars is that it had some drivabilty issues then was parked for a year because of the those issues. I know no other details as i am the new owner.
no trouble codes other than 55 ( none trouble found )
gets
