Old Dec 2nd, 2006, 02:24 PM   #1 (permalink)
vash.t.s.
Send a message via Yahoo to vash.t.s.
Question More Problems
I just had to replace my radiator, i went to the junkyard and replaced it with one from a manual 240sx (mines auto), had a little trouble with all the plastic crap but its in, i connected the automatic transmission cooling lines to the new radiator, flushed the system but now my car is running funny. My rpms are running dangerously low, like below the 500 mark, i checked all my vacuum lines and the only thing that could be bad is i think i might have a slight crack in my line from the pcv valve to the throttle body. (its an old line) my second problem is when i'm driving the trans stays in first for far too long, and when it shifts to 2nd it shift hard. i'm going to be doing a full tune up soon, but with all the bad weather and limited access to a garage its hard. i was wondering if nebody had any insight on what i should do. oh yeah i did put about a quart of auto transmission fluid in it to compensate for what i might of lost doing the radiator swap.
vash.t.s. is offline   Reply With Quote
Old Dec 2nd, 2006, 02:52 PM   #2 (permalink)
SonsofWisdom
SonsofWisdom's Avatar
are the ecu's different for auto and manual...I'm pretty sure they are...this could be a big problem because the ecu handles the engine differently with an auto..has more control
I'm sorry, I didn't quit catch that line of bull that just plopped from your mouth
SonsofWisdom is offline   Reply With Quote
Old Dec 2nd, 2006, 08:12 PM   #3 (permalink)
Madmaxfl
Madmaxfl's Avatar
You say you replaced the automatic transmission radiator with one from a manual and connected the transmission lines to the radiator. I am assuming there were identical connections as were on the radiator that you took off? You need to check the automatic transmission fluid level to make sure it is right do not just add what you think is the right amount. Also you should have done a fluch of the junk yard radiator including the transmission fluid portion to make sure you did not introduce any junk into the systems.
Madmaxfl is offline   Reply With Quote
Old Dec 3rd, 2006, 05:30 AM   #4 (permalink)
vash.t.s.
i did flush the system with the new radiator in it, just not the transmission fluid part, which is probably my biggest mistake, i heard it is hard to drain and refil the transmission, i just put the fluid where i removed the dipstick. is it extremely bad to overfill the autotransfluid?
Old Dec 3rd, 2006, 05:32 AM   #5 (permalink)
vash.t.s.
oh yeah sorry if it made like i did a big swap i only replaced the radiator and the only choice i had was to take it from a manual car which did fit all lines the same, so i didnt mess with ecu, same everything just different radiator
Old Dec 3rd, 2006, 10:17 AM   #6 (permalink)
rogoman
Super Moderator
rogoman's Avatar
Here are the possibilities for the hard shifting:
- bad TPS resistance element
- bad TPS harness connection
- auto tranny dropping resistor not connected or defective
The tranny cooler portion in the radiator should always be thoroughly flushed when replacing a radiator. Any loose gunk can get into the tranny valve body and screw it up.
Old Dec 4th, 2006, 12:25 AM   #7 (permalink)
SonsofWisdom
ah...gotcha...my bad...
Old Dec 4th, 2006, 09:44 PM   #8 (permalink)
vash.t.s.
well, im going to flush my transmission and see if the shifting is any better, theres another weird thing though, when i used to floor my car when it was in 2nd or 3rd it'd drop a gear to accelerate faster, but now when i floor it it just stays in the same gear and the pickup is real slow.
Old Dec 4th, 2006, 10:29 PM   #9 (permalink)
zellx2004
Nismophiliac
zellx2004's Avatar
Send a message via AIM to zellx2004 Send a message via Yahoo to zellx2004
sounds as though that radiator may not be as good as you think. It sounds as though there is something in the trans cooling portion of the radiator preventing the transmission from building adequate pressure (hence you having a hard shift). I"m not totally sure, but it may also be the cause for the rpm's dropping as well...Might I suggest saving and buying a new oem radiator from a local autoparts store.
LAST Chance! 89 240sx for sale. S13 conversion 2 sr20's needs some work in order to run. 1000 USD. email for pictures.
zellx2004 is offline   Reply With Quote
Old Dec 4th, 2006, 11:05 PM   #10 (permalink)
vash.t.s.
thanks ur probably right are there places that i could take the radiator to and have it tested?
Old Dec 5th, 2006, 12:04 AM   #11 (permalink)
zellx2004
Nismophiliac
zellx2004's Avatar
I guess you can try an A/C shop? Some of the A/c shops here in columbia work on radiators as well as hvac systems.
acceleration and idle problems denski U13 1993-1997 Altima 5 Jan 19th, 2005 12:44 AM
Help! 95 SE Stalling/Hesitation Problems While Cold reeddy Truck & SUV 0 Nov 11th, 2004 12:20 PM
Problems, problems and more problems blitzboi L31 2002 - 2006 5 Aug 21st, 2004 12:18 AM
Spec-v Problems BuehlerBJ New Member Forum 21 Jun 26th, 2003 08:16 AM
CAI Problems anyone? Quick1 SR-Series Engines (DE/VE) 12 Apr 14th, 2003 08:06 PM
