Old Nov 9th, 2006, 07:33 PM   #1 (permalink)
gizeye
5mph max / fuel not feeding?
my 240 is not getting enough fuel..
i can drive a max of 5mph then my car bugs out/gives up on the acceleration (engine still stays on)
i do have a fuel pressure regulator.
and i just changed fuel pumps recently (used) so im not sure whats goin on.
help please?
gizeye is offline   Reply With Quote
Old Nov 10th, 2006, 04:43 AM   #2 (permalink)
mitch1988
Send a message via Yahoo to mitch1988
i had the same problem with my old eagle talon
change your injectors once or get them cleaned
because it turned out my injectors were clogged
and see if that help if not contact me and i got something else for you to try
mitch1988 is offline   Reply With Quote
Old Nov 10th, 2006, 04:52 AM   #3 (permalink)
mitch1988
o plus check the fuel filter sometime if you have an older car and if you are running on E your fuel pump could suck up some crap from your tank and get clogged so that would also be another thing to check so you have to check
1) fuel filter for crap clogging it
2) Pump clogged with shit
3) Get your injectors cleaned or just try some other ones if you have them laying around
4) Also could be the ecu diodes but check 1 though 3 first then get back to me if that dont work or ya and number 5
5) good luck
Old Nov 10th, 2006, 08:29 PM   #4 (permalink)
gizeye
ive recently changed the injectors and ecu. also i recently replaced the gas tank so the fuel filter shouldnt be clogged.
im thinking it might be the MAFS... i want to make sure before i buy and replace it.. but i dont know how to check..
opinions please?
Old Nov 14th, 2006, 12:35 AM   #5 (permalink)
mitch1988
the best thing to do it check how much ohoms or restitance has to be going thou it
Old Nov 14th, 2006, 07:20 AM   #6 (permalink)
Dan9
Certified Ghetto Mechanic
Dan9's Avatar
my MAF wiring was bad. You can pull the codes from your ECU, if you get a MAf code then its either the MAF OR the harness.
To check the harness you need a multimeter (ohmmeter) and a wiring diagram, disconnect the ECU then check for continuity between each pin on the MAF connector (just ease back the rubber boot on it so you can see the color code of the wiring) and its corresponding pinout at the ECU harness.
Even the Haynes manual probably has a procedure to check MAF function, you use a voltmeter and check the voltage variation,
course I dont have a 240 so what do I know, burt Im sure its similar.
D
I like my tin can car
Dan9 is offline   Reply With Quote
91 NX1600 runs for a week, dies then wont start for 2 days...intermitent pattern triplefour B13 91-94 chassis 4 Jul 31st, 2008 07:06 AM
89 Sentra Cranks, Won't Turnover (has spark & fuel) Firestone Stumped nneuhof E/CA-Series & GA16i Engines 3 Jul 7th, 2006 10:37 AM
Carter fuel pump; how to hook it up? narx E/CA-Series & GA16i Engines 4 Sep 12th, 2005 05:50 PM
Turbo for sr20de (Sticky Please) onyxeros Forced Induction & Nitrous Oxide 47 Feb 18th, 2004 11:54 PM
fuel leak> evaporative canister sailer291 Truck & SUV 5 May 6th, 2003 09:58 PM
