JDM imports direct s13 rb26 is running twin gt3037's and it's still lhd so that steering shaft issue isn't a problem. you just have to work with it. THe rb26 swap is similar to the other rb series swaps, with the exception of the transmission. you have to use a trans from the RB25, and with this you have to use the RB25 oil pan as well. (I've been told this is the hardest part of the swap.) Driftfactory.com has a small write up on it. you may want to check them out.
LAST Chance! 89 240sx for sale. S13 conversion 2 sr20's needs some work in order to run. 1000 USD. email for pictures.
