Old Jul 7th, 2006, 01:13 PM   #1 (permalink)
2nyce
SR20 CT emissions help
I'm new to this forum so i don't kno how this exactly works..neways im lookin to buy this s13 sum guy has but it has a full 3'' stainless exhaust and i want to buy it but i dont kno how i can pass emissions so i can get it registered.
2nyce is offline   Reply With Quote
Old Jul 7th, 2006, 01:40 PM   #2 (permalink)
2nyce
Also id like some advice on buying the car..the guy wants to me trade my 97 jetta gls +$1500 for his 90 240 with the sr swap already done. My jetta has some mechanical problems as far as the suspension and i think theres a problem with the cv's too, but the engine is fine(it's the 2. slow in case ur wondering). On the other hand, the 240 has intake, full 3'' exhaust, koyo radiator, front mount inter, supposedly performance cams, and performance clutch. only problem with it is the hatch has a huge rust hole in it and needs to be replaced. Also, the car doesnt want to hold the idle. she'll start but in order to keep her running u have to keep the revs at around 4000 till she warms up then she purrs like a kitten. Im not sure wat the problem is it could be a sensor but i want to believe its the "performance cams." Any insight on this matter would be greatly appreciated.
Old Jul 7th, 2006, 11:50 PM   #3 (permalink)
chris859
Just another nissan fan!
Send a message via Yahoo to chris859
The value difference Is impossible to tell you without looking at both cars. If the swap was done right in the 240sx, and it is for the most part a nice car - and your car is a kinda crappy, beat down car then yeah...killer deal. The idling issue - aftermarket cams won't keep a car from idling, thats just plain silly - it is most likely a bad sensor, or idle control valve.
chris859 is offline   Reply With Quote
Old Jul 8th, 2006, 12:07 PM   #4 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
Or a MAFS.........Sound like a good deal...as for emissions many pass...depending if they have a visual inspection...usually most fail for visual. Depends on your inspector
Trippen
"I reject your reality and substitute one of my own" Adam-Myth Busters
" I dont give Frequent Flyer miles for Guilt Trips"
89 240SX SE FB -KYB AGX w/RS-R race Springs. [
95 240sx se KA-T Borded .20 over JWT ECU, Z32 MAF, Arias Pistons, Eagle Rods, 50 trim T3/T4 turbo, 50lb MSD, J30 LSD, Custom Drive shaft,D21 flywheel,PLX-R500 and TurboXS Knock lite keeping tabs on everything
fastback-hatch-rattle-fix-how-too.html
Trippen is offline   Reply With Quote
Old Jul 9th, 2006, 07:01 PM   #5 (permalink)
2nyce
Thanks for the advice guys..i was thinkin it was the MAF if it is where should i go 2 get a new 1 if cleaning it doesnt work? ya my jetta is garbage...:P
Old Jul 9th, 2006, 07:06 PM   #6 (permalink)
2nyce
Also i want to get a cat for it should i go with a cat from like an se-r or a cat from a 240.
Old Jul 9th, 2006, 11:54 PM   #7 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
Ebay or a local shop that does sr20 swaps....they throw away a ton of good parts
Trippen
sr20 redtop vs sr20 blacktop....... Th3_Juice SR20DE/DET Engines 14 Sep 21st, 2006 06:30 PM
JDM sr20 deStroyER SR-Series Engines (DE/VE) 6 Jun 12th, 2004 01:14 AM
Thinking GTi-R SR20 swap.....emissions? GT3man2001 B14 95-99 chassis 9 May 3rd, 2004 07:55 PM
SR20 Durability? Need an honest answer... meridian5i2 SR-Series Engines (DE/VE) 36 Jul 1st, 2003 07:13 PM
SR20 Emissions Legal? Elemental S14 240SX 1995-1998 12 Jun 10th, 2003 03:07 PM
