Old Jul 1st, 2006, 06:19 AM   #1 (permalink)
24EQ
Exclamation Need valve cover torque specs
Hello folks, I need the torque specs for the valve cover bolts. I have a 1990 240sx. And also I have a dumb question to ask. I believe I have a KA24E engine but I see that others with the same year car say they have an S13. What is the difference????
24EQ is offline   Reply With Quote
Old Jul 1st, 2006, 08:05 AM   #2 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
Ok first off an S13 isnt a motor spec but a body spec....S13 is from 89-94(?) then S14..
On your motor if it is a KA24E then it has the spark plugs to the right of the motor not in the center.....and on the Valve cover it says SOHC....
I have checked my 3 sources of Nissan Docs and I cant find a valve cover torque spec.....I usually do mine to hand tight....On my calibrated hands usually 20-25Inch Measured cold LBS....I havent had an issue so far no oil leaks to speak of.
Trippen
"I reject your reality and substitute one of my own" Adam-Myth Busters
" I dont give Frequent Flyer miles for Guilt Trips"
89 240SX SE FB -KYB AGX w/RS-R race Springs. [
95 240sx se KA-T Borded .20 over JWT ECU, Z32 MAF, Arias Pistons, Eagle Rods, 50 trim T3/T4 turbo, 50lb MSD, J30 LSD, Custom Drive shaft,D21 flywheel,PLX-R500 and TurboXS Knock lite keeping tabs on everything
fastback-hatch-rattle-fix-how-too.html
Trippen is offline   Reply With Quote
Old Jul 1st, 2006, 09:56 AM   #3 (permalink)
rogoman
Keeping the peace
rogoman's Avatar
initial tighten: torque spec is: 3 nm (2.2 ft lb).
final tighten: torque spec is: 7 - 10 nm (5.1 - 7.2 ft lb).
Old Jul 1st, 2006, 10:15 AM   #4 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
Thanks Rogoman what source did you get these from?
and For those who dont have a footlb wrench at such a low range here are the number in inch lbs
3 nm (2.2 ft lb) or 26.4 inch lb
7 - 10 nm (5.1 - 7.2 ft lb) 62inlb 86.4inch lb
Trippen
Old Jul 1st, 2006, 02:06 PM   #5 (permalink)
SHpaintball
SHpaintball's Avatar
thanks i have been lookin for that 2
SHpaintball is offline   Reply With Quote
Old Jul 1st, 2006, 04:18 PM   #6 (permalink)
24EQ
Thanks a lot guys, I knew I came to the right place. Oh yeah, and another thing. How do you change your avatar to a photo from your own gallery? I would like to put in a picture of my own 240.
Old Jul 1st, 2006, 04:42 PM   #7 (permalink)
Nismo240
i'm an asshole
Nismo240's Avatar
i believe you have to resize it to make it fit.
i rape noobs so GTFO.
Nismo240 is online now   Reply With Quote
Old Jul 1st, 2006, 06:28 PM   #8 (permalink)
rogoman
Keeping the peace
rogoman's Avatar
Hey Trip,
I happen to have a 1990 Nissan FSM. Got it from there.
Old Jul 1st, 2006, 10:39 PM   #9 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
Hey Trip,
I guess my FSM ...Digital isnt as complete/...easier to travel with though
Trippen
Old Jul 1st, 2006, 10:41 PM   #10 (permalink)
Trippen
Nissan Fanatic
Trippen's Avatar
Hey Trip,
I guess my FSM ...Digital isnt as complete/...easyer to travel with though
As for changing your advitar I became a contributor to do it
Trippen
Old Jul 3rd, 2006, 04:10 PM   #11 (permalink)
SIL-S15
are these the same torque specs for the DEs?
also i found a diagram a while back on the DEs valve cover and in what order to tighten the bolts its like a criss cross action or something i cant remember and i cant find that site anymore any info on this guys? thanx
SIL-S15 is offline   Reply With Quote
Valve Cover Leaking socalzbone Z32 Chassis 300ZX 22 Oct 21st, 2005 07:19 PM
Valve cover gasket + spark plug seal ppupet L30 1998-2001 Altima 1 Jul 2nd, 2004 06:59 PM
Valve cover problems! Derrick GA16DE 1.6L Engine 3 Jun 9th, 2004 04:27 PM
valve cover gasket hector200sx GA16DE 1.6L Engine 3 Jun 1st, 2004 11:04 PM
sr20de valve cover torque specs sr20speed SR-Series Engines (DE/VE) 2 May 20th, 2003 04:33 PM
