engine trouble 240sx ka24de 92'
i just bought a 92' 240sx in which the cylinder head needed to be surfaced because coolant was leaking into the engine. well i got it surfaced and they had to take off 10 thousandths of an inch. anyways, it started up fine before i took it apart, but now that its back together it wont start. when i first cranked it over after the work, it started right up, but it started to run rough so i cut it off. i tried to start it back up right after and it wouldnt start. i cleaned off the spark plugs and let the engine sit for a couple days, but it still wont start (it turns over though). i checked all the connections and i made sure the timing was all lined up before putting it back together. i'm still somewhat of a novice with major engine work. i can't figure out whats wrong with it, can someone give any advise please?
