remove the shroud for the fan, losen all the belts and pull them off, remove the fan, and the underdrive pulley, and its rite underneath that dont forget to drain ur coolant lol. get a new nice waterpump it is worth it in the end also if you are doing that u should do ur thermostat also thats pretty easy also just un bolt the power steering pump and have a friend hold it while un bolt the housing. hope this helps
