Ok here is the problem im tired of being pulled over so i need to fix my head lights first off. Only the left side headlight turns on unless i turn my brights on that headlight turns off and the other headlight turns on as the bright. kinda weird dont know where to look for that. The second problem is that my head lights stopped moving. this happend after i was wireing up my oil pressure guauge. Fuse is good so i dont know what went wrong there. So any advice would help.
My Rides=
93 240sx coupe mods=none hope to make Ka-t soon
Slammed 83 s-10
88 Ford Ranger 4x4 (for sale)
"The person that said that the pen is mightyer then the sword hasn't seen automatic weapons."
Mess with the best and die like the rest!
are you talking about my hazard lights? ok... or are you talking about he button that controls the light dimmer if so that dosent work.
My Rides=
Slammed 83 s-10
I just had this problem today. It happened after I took my car through a wash. I found that my plug on my for the right light into the harness (about 1 foot behind the light) was just soaked in water IE still had water in it) A. Follow the wire back disconnect it and see if you have any water in it. Check to see if the light plug has a ground on both outter pins. With the lights on Disconnect the plug from the back of the light there will be 3 contacts two even with each other and the middle one lower. Take a Multimeter on Ohms and put one lead on one of the outside pins. and touch the other lead to ground. Only one should have 0 ohms on it the other outside pin should have a open. Then put high beams on and the 0 Ohms should be on the other pin. This is a quick way to tell if you have a gounded condition in your lights. This was my issue today and it took me and 2 neghibors 3 kids and 2 Mountain Dews one busted knuckle to fix it. Good luck
__________________ Trippen
"I reject your reality and substitute one of my own" Adam-Myth Busters
" I dont give Frequent Flyer miles for Guilt Trips"
89 240SX SE FB -KYB AGX w/RS-R race Springs. [
95 240sx se KA-T Borded .20 over JWT ECU, Z32 MAF, Arias Pistons, Eagle Rods, 50 trim T3/T4 turbo, 50lb MSD, J30 LSD, Custom Drive shaft,D21 flywheel,PLX-R500 and TurboXS Knock lite keeping tabs on everything fastback-hatch-rattle-fix-how-too.html
the same thing happened with my headlights. i did the H4 conversion and put in some hyper white bulbs. i just changed out the bulb and now its been fine. i dont know if this is any help but i think it would be worth a try. my first bulb only lasted about 2 1/2 weeks, but the new one i put in has lasted about 2 months now.
