Old Feb 21st, 2006, 03:46 PM   #1 (permalink)
Polah Bear
Send a message via Yahoo to Polah Bear
Cooling fan question...
Can I gain more power by removing the clutch fan off my Ka and replacing it with an electrical fan? Just a random question...
Polah Bear is offline   Reply With Quote
Old Feb 21st, 2006, 11:11 PM   #2 (permalink)
Lost_DriFter
Send a message via AIM to Lost_DriFter
indeed u will but i heard bad reviews about the electric fans but yea ull gain power by removing the clutch fan (less strain on the motor) electric fan is a space saver too
I love Pancakes
Broke Man Project.....
Lost_DriFter is offline   Reply With Quote
Old Feb 22nd, 2006, 04:17 PM   #3 (permalink)
Polah Bear
Cool! I will be using an electric fan off a newer passat. it lines up almost perfect over my radiator and the fan blade diameter is bigger then my clutch fan. What problem could an electrical fan cause other than not blowing enuf air?
Old Feb 22nd, 2006, 04:29 PM   #4 (permalink)
xs04298
xs04298's Avatar
Send a message via AIM to xs04298 Send a message via MSN to xs04298
electrical failures..but, if you do it right it'll be just fine..
1989 240SX H/B
Have a burgandy/red s13? about to change out hoods? i could use it!
xs04298 is offline   Reply With Quote
Old Feb 22nd, 2006, 05:49 PM   #5 (permalink)
zellx2004
Nismophiliac
zellx2004's Avatar
Send a message via AIM to zellx2004 Send a message via Yahoo to zellx2004
perma cool has a single 14" fan. It's about 100 bucks (junior bacon cheeseburgers for all us fat people) and flows about 1800 cfm. not bad IMO.
LAST Chance! 89 240sx for sale. S13 conversion 2 sr20's needs some work in order to run. 1000 USD. email for pictures.
zellx2004 is offline   Reply With Quote
Old Feb 22nd, 2006, 08:26 PM   #6 (permalink)
Polah Bear
what is cfm?
How much cfm is my clutch fan pushing?
Old Feb 22nd, 2006, 09:11 PM   #7 (permalink)
zellx2004
Nismophiliac
zellx2004's Avatar
what is cfm?
CFM is how air is measured. Most commonly found on Carburetors (sp?) Generally more air the better. I'm unsure about the stock fan. I do know that heavythrottle.com used that 14" perma cool fan with a koyo on their SR to keep it cool.
Old Feb 23rd, 2006, 03:27 AM   #8 (permalink)
kaptainkrolllio
Finally got a user title
kaptainkrolllio's Avatar
There really isn't a disadvantage to switching to an electric fan if you don't screw up the wiring and short it out. It's lighter, frees up a few horsepower, quieter, takes up less space, and will likely cool better than stock.
Originally Posted by Zen31ZR
Kinda like speed-limit signs, it's merely a suggestion.
kaptainkrolllio is offline   Reply With Quote
Old Feb 23rd, 2006, 05:13 PM   #9 (permalink)
Polah Bear
Ok...so I keep hearing about the wiring. What is the best way to wire it up? I was thinkin of using a thermostat switch vs relay/ign or relay/rocker switch.
Old Feb 23rd, 2006, 07:46 PM   #10 (permalink)
rogoman
Keeping the peace
rogoman's Avatar
what is cfm?
cubic feet per minute
Old Feb 23rd, 2006, 09:00 PM   #11 (permalink)
180SX-X
Nissan Addict
180SX-X's Avatar
Well, you could wire it up so it can be operated manually..use the "sticky" to get an idea of it better..but basically, if you know how to wire a radio from scratch, same thing, just a power cable to battery(or any major power point, such as the fuse box), include a inline fuse to it, a ground cable to a good chassis ground(some people do it to the battery, but a chassis ground is beter IMO), and a toggle switch(on-off) in either of the wires(better to do power)..simple..how you wire it and place it is up to you..
A wise man once told me, 'If you drive to win, you're digging a new hole, but if you drive for passion, its already been dug up.'
If you're a driving person, this saying has meaning..
180SX-X is offline   Reply With Quote
Old Feb 23rd, 2006, 09:41 PM   #12 (permalink)
Joel
Pivot 180
Joel's Avatar
battery power aint free
use a relay and a thermo switch please! inline switch is dodgy.
SilviaWA
1992 180SX: cwest, vertex, wise, pivot, gemax, embleton, kyb, blitz, whiteline
Joel is offline   Reply With Quote
Old Feb 24th, 2006, 12:46 AM   #13 (permalink)
Polah Bear
Exactly my thought....thanks everybody!
NEW... PLEASE HELP! COMPLETE CAR NOVICE!! lggkerry U13 1993-1997 Altima 5 Mar 29th, 2005 09:52 PM
98 Frontier, fan motor speed control question BLfrontier Truck & SUV 1 Nov 26th, 2004 11:22 AM
87 Maxima cooling fan problem Tirby General Maxima Discussion 2 Jul 27th, 2004 06:52 PM
More info on my AC fan situation Bugalou B11/B12/KN13 82-90 chassis 6 May 16th, 2004 09:43 PM
Newbie/ Fan question Shift_NX B13 91-94 chassis 5 Mar 9th, 2003 09:51 AM
