HEY GUYS I WANTED TO KNOW IF I HAD THE CORRECT TORQUEING NUMBERS FOR THE VALVE COVER IS IT 8 ft/lbs???
ALSO IS THERE AN ORDER THE BOLTS HAVE TO BI TIGHTEN IN??? AND WHATS INCLUDED IN A VALVE COVER GASKET SET?
THANX GUYS....
I thought the torque spec was in inch lbs... However when I do mine I just lightly snug it all the way around and then repeat. You don't want the valve cover to be super tight. You'll pinch the gasket if you do and defeat the purpose of the whole replacement.
R.H.D s13-->T04E RB20DET
Wangan Stylez Super Stars Team
i dunno im trying to find out if thats the correct torque spec??? along with the others things im asking.....
