rear caliper messed up and leaking fluid?
ok, i was trying to bleed my brakes again because i have to pump them a couple times to get them to work. anyways, when i got to the left rear wheel, i noticed there was brake fluid leaking from the caliper. has anyone had this problem? when you pump the brakes, it comes out pretty fast. would that cause the whole brake system to not work that great and make it so i have to pump the brakes before they work properly?
