» Auto Resources
Find Nissan prices on trucks such as a Nissan Xterra, Nissan Frontier and more. Find inexpensive auto leasing rates on a new Nissan such as a Nissan 350Z.
» Sponsor Links
»Garage Storage and Cabinets
Old Dec 1st, 2005, 08:59 AM   #1 (permalink)
SmashThat
chain whip caused small crack/hole in timing cover
so there is a small crack/hole in my timing cover which caused water and oil to mix. the car was driven to my house. it ran rough. but i started tearing it apart before i did a compression test. what are the chances that my bottem end is ruined. would it have ran at all? i'm replacing the chain, head and some gaskets. is there a decent chance this car will run again?
SmashThat is offline   Reply With Quote
Old Dec 1st, 2005, 09:13 AM   #2 (permalink)
ddude2uc
If you hurry up & fix your timing chain & replace the head gasket,(since your replacing the head) you should come out ok. The longer your let it sit & don't flush out the water, you rod & main bearings will rust, including your cylinder walls.
ddude2uc is offline   Reply With Quote
Timing Chain for 1996 Altima 1996nissanlover U13 1993-1997 Altima 18 Jan 2nd, 2008 09:30 AM
Help with Z24 Timing Chain BobbyM Truck & SUV 5 Oct 21st, 2005 06:51 PM
Timing Chain replacement schedule! kkspeed Truck & SUV 4 Mar 19th, 2005 02:53 AM
New Timing Chain troubles... SilviaTurbie S13 240SX 1989-1994 5 Mar 7th, 2005 12:59 PM
lower timing chain tensioner cbeebe79 GA16DE 1.6L Engine 7 Jan 20th, 2004 09:22 AM
