clutch problem- replaced master & slave cylinder
The 1993 5 speed 240sx does not want to shift gears. When it's cold, there is no problem. However, after it warms up when I push in the clutch it does not want to go into the next gear. When you turn off the car and then start it in gear it jumps, like you are trying to push start it. They replaced both the master and the slave cylinder, asa well as bled the clutch. There is no play in the clutch, however you hear a "spinning like sound" sometimes when trying to shift gears. It felt as if it is happening right under my feet under the the floorboard. I cannot afford another "misdiagnosis" by the mechanic. What do anyone suggest???
