Old Jan 18th, 2005, 05:50 PM   #1 (permalink)
Evil_Twin
Send a message via AIM to Evil_Twin Send a message via Yahoo to Evil_Twin
Whistling Noise at around 2-3k
I'm breaking in my car, and I haven't gotten it over 3k other than once or twice. I notice anywhere around 2-3k if I put the clutch in, theres a faint whistling noise. Sounds like when you put a new intake manifold on and dont scrape all the gasket off. But if its under 3k it doesn't make it, and when its over 3k, it doesn't make it.
Haven't really looked under the hood since it's been soo cold out. Thanks.
2005 Nissan Sentra SE-R Spec V
Evil_Twin is offline   Reply With Quote
Old Jan 20th, 2005, 01:01 PM   #2 (permalink)
BlackoutSpecV
Nissan Addict
BlackoutSpecV's Avatar
The QR25 makes some weird noises at various RMP's (in my opinion of course). I remember early on I heard a 'whine' from the car at around 2500-3000... it either went away or I got used to it. I would not worry, if there was a leak the ECU would/should pick it up and throw an SES light.
-- 2002 SE-R Spec V
BlackoutSpecV is offline   Reply With Quote
Old Jan 21st, 2005, 09:31 PM   #3 (permalink)
Evil_Twin
Could it be the throw out bearing being broken in?
Old Jan 22nd, 2005, 12:02 PM   #4 (permalink)
ittamaticstatic
Tune it
ittamaticstatic's Avatar
Send a message via MSN to ittamaticstatic Send a message via Yahoo to ittamaticstatic
Bearings don't make any sounds unless they're going bad. They growl when they're bad. The throw out bearing is only engaged when you disengage the clutch.
ittamaticstatic is offline   Reply With Quote
Old Jan 22nd, 2005, 12:05 PM   #5 (permalink)
ittamaticstatic
Tune it
If it's like a whine it's your gears. They are breaking in probably and I personlly like to change the gear oil at around 10,000 miles to get rid of any metal shaving from the gears out from the break-in. Most of the shaving will be on your magnetic drain plug either way.
Need help with tire noise on NX jb-nx2k New Member Forum 5 Mar 5th, 2006 07:03 AM
Pathfinder makes whistling noise Gene Truck & SUV 3 Nov 2nd, 2004 05:30 PM
Whistling noise when turning janissan Truck & SUV 1 Aug 4th, 2004 12:14 AM
99 GXE Whistling Noise? mjs99 L30 1998-2001 Altima 3 Jul 27th, 2004 11:23 PM
Whistling noise from rear? Topshelf Truck & SUV 0 Apr 14th, 2004 07:54 PM
