I think you will be fine... BTW- where did you order these from?
03 Spec V Custom CAI/2.5 inch downpipe-back exhaust/2.5inch downpipe/Balance shaft removal/Stillen Header/Knock sensor relocated and grounded/JWT clutch/JWT flywheel/Weight Reduction(100+Lbs)/ES Motor mount inserts/Stillen QR-Pro/Casper O2 Sim/Ground Wire Kit/JWT Cams
