Originally Posted by formula4speed
Sounds like it could be a leak. What gaskets did you use when installing? Did you remember to re-tighten the bolts after a week of use?
I used the supplied gaskets for the bottom but reused the gasket from the header from the original. Also when Im driving and i set the AC to allow air from outside and im not moving I can smell exhaust smoke. Ideas?
I did retightne after a week
