Old Sep 21st, 2002, 11:01 PM   #1 (permalink)
Murph
Nissan Fanatic
Send a message via ICQ to Murph
aftermarket knock sensor
Relocating the knock sensor to the firewall is definitly a fix for its oversensitivity.
But if i want to be relatively sure there is no detonation going on a knock sensor helps. Why are they not available as an aftermarket part?! I wouldnt have thought they would cost much to produce.
If im totally overseeing something here, go easy one me!
http://is2.dal.ca/~mpmurphy/sig.jpg
Drive Safely!
Murph is offline   Reply With Quote
Old Sep 23rd, 2002, 06:22 AM   #2 (permalink)
cortrim1
Nissan Fanatic
cortrim1's Avatar
Talking Re: aftermarket knock sensor
Detonation will not be a problem I have had mine done for about 3 months and had no problems. As for a after market knock sensor it would not fix the problem because its in nissan program in the ecu. You could make the sensor less sensitive by using a resistor if you can get a copy of the fsm.
:thumbup:
02 spec (173.1whp,178.9lbft)retired
94 se-r (342whp, 289lbft @15psi)
92 se-r (sr20ve with N1 cams DD)
www.cardomain.com/id/cortrim1
cortrim1 is offline   Reply With Quote
Old Sep 23rd, 2002, 01:00 PM   #3 (permalink)
Murph
Nissan Fanatic
thanks learn something every day
Drive Safely!
EVAP canister vent control valve closed large168 SR-Series Engines (DE/VE) 32 Oct 3rd, 2008 03:11 PM
knock sensor ?!?! johnnykomac SR-Series Engines (DE/VE) 13 Dec 25th, 2005 02:37 PM
knock sensor p10driver SR-Series Engines (DE/VE) 3 Jul 31st, 2003 11:50 AM
knock sensor voltage mx702 SR-Series Engines (DE/VE) 16 Jul 1st, 2003 03:45 PM
knock sensor and balance shaft NEWBIE NISMO82 QR25 2.5L Engine 4 Feb 14th, 2003 11:00 PM
