Idle learning & Idle air volume learning - Nissan Forum
post #1 of 12 Old Apr 30th, 2004, 07:50 AM Thread Starter
I have an 04 SER. 3k Mi. Hot shot header and CAI. I have idle problems 2 days after install of CAI. On QR25DE.Net they talk about idle problems after disconnecting the battery. They say that you may need to preform the Idle & Idle Air Volume Learning. Does anyone know this procedure? Help!
pratali21 is offline
post #2 of 12 Old Apr 30th, 2004, 10:06 AM
Powered By hopes & dreams
chimmike's Avatar
the ECU learns by itself.
go back and check all the fittings, all the connections, etc.
unplug the negative terminal of the battery for 10 mins, (reset the ECU) and see how it runs.
only real motored toys left:
'06 GSX-R 1000
'07 Mazdaspeed3- injen CAI.
chimmike is offline
post #3 of 12 Old Apr 30th, 2004, 10:26 AM
And justice for All!!!
vector03's Avatar
Send a message via AIM to vector03
TSB Code: NTB04015
I know there's a TSB report out about idle. Check this sight out and see if this sounds like your problem
Clicky
"For the last time Token, you're Black. You can play Bass Guitar."
vector03 is offline
post #4 of 12 Old Apr 30th, 2004, 11:37 AM
lucky_azz_jojo's Avatar
ok...i have recently bought NISMO CAI GEN II and i did install it myself...but now it idles funny...it would idle normal then all of a sudden it would drop idle and the whole engine would vibrate like it was gonna turn off...and it waould idle normal again...i would keep doing that...what do you think it could be?
oh when i put my CAi i was rippin out the stock intake like a mad man...and when i was puttin the NISMO CAI i noticed a lil hose that came from transmission or something around there...i dunno if it connected to the stock intake or if it was mounted somewhere...but i looked at the stock intake and there was no place for the lil hose and the hose look like it wasnt connected...can someone share some info of what that was?
o4' Silver Spec V
Tein SS Damper Kit, Nismo CAI Gen II
lucky_azz_jojo is offline
post #5 of 12 Old Apr 30th, 2004, 12:59 PM Thread Starter
TSB Code: NTB04015
That sounds like the problem. I have the procedure from QR25DE.net web site but its worded werd on 4 & 5 of the steps and I can't get to work. The name of the forum is Idle Learning. Does anyone know this?
post #6 of 12 Old Apr 30th, 2004, 03:09 PM
Nissan Addict
BlackoutSpecV's Avatar
do not worry about that, just zip-tie it to something in the engine bay. (tranny breather line or something)
Mike is correct, the ECU is self learning. Figure it will take about 2 weeks to fully adjust. Even with stock intake the car is sometimes choppy at idle when you first stop.
-- 2002 SE-R Spec V
BlackoutSpecV is offline
post #7 of 12 Old Apr 30th, 2004, 04:03 PM
oh ok...so is there to chill somwhere...its not meant to be hooked up to the intake
o4' Silver Spec V
post #8 of 12 Old May 2nd, 2004, 06:48 PM
cysco00's Avatar
Funny enough, I was going to post a thread about this problem about 3 weeks ago after I got my NISMO CAI!! My car kept doing the same thing.....at idle it would drop the RPM's so low as to almost kill it!! After tightening up my connectors and resetting my ECU (which I forgot to do in the first place) it didn't do it as bad!!
Now, three weeks later it is virtually gone!! Idle still drops a little but not much at all to where you feel it!!
Cisco C.
cysco00 is offline
post #9 of 12 Old May 3rd, 2004, 10:00 AM Thread Starter
Learning
I did the Throttle Learning and the Idle air volume and its a little better but its still there.
Cisco C.
post #10 of 12 Old May 3rd, 2004, 12:30 PM
Cisco C.
i tightened my connectors and the problem went away!!...but my RPM's doesnt drop anymore!!!...but it will drop a lil but its hardly noticable and it will do it sometimes tho
i noticed i can go pass my rev line!!...i think it reved it up to 6.5...but i need to try it again...its pretty coolz tho...has anyone went pass their rev line??
o4' Silver Spec V
post #11 of 12 Old May 5th, 2004, 02:50 AM
TECKADEMICS
Our tach's aren't that precise... your not really hitting 6500 rpm, trust me.
03 Spec V Custom CAI/2.5 inch downpipe-back exhaust/2.5inch downpipe/Balance shaft removal/Stillen Header/Knock sensor relocated and grounded/JWT clutch/JWT flywheel/Weight Reduction(100+Lbs)/ES Motor mount inserts/Stillen QR-Pro/Casper O2 Sim/Ground Wire Kit/JWT Cams
1YellowSpecV is offline
post #12 of 12 Old May 5th, 2004, 12:26 PM
oh ...that sucks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
o4' Silver Spec V
  Nissan Forum > Sentra, Pulsar, NX, B14 200SX > QR25 2.5L Engine
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
