» Sponsors
» Sponsors
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > QR25 2.5L Engine
Old May 11th, 2004, 12:10 PM   #46 (permalink)
Friends of ours...
Ruben's Avatar
I WANT PICTURES!
Ruben is offline   Reply With Quote
Old May 11th, 2004, 01:05 PM   #47 (permalink)
Skylines Little Bro's Avatar
Send a message via MSN to Skylines Little Bro
Originally Posted by lshadoff
There is no way that a factory equipped engine should have this problem. It is a design fault if the piston hits a spark plug under any driving conditions unless it is over-revved.
I suggest you contact Nissan to find out if this is a problem known to them. If not, report it and tell them that the dealer will not help you.
Try this link
Lew
ok thanks man
Skylines Little Bro is offline   Reply With Quote
Old May 11th, 2004, 01:08 PM   #48 (permalink)
Originally Posted by Ruben
I WANT PICTURES!
you want pics of the mark on the piston??? ya i can try and do that as soon as possible.
Old May 11th, 2004, 01:27 PM   #49 (permalink)
Come here often?
BikerFry's Avatar
For the guys who are worried about decelerating at too high of an RPM... Uh, there is NO reason why the piston should contact the plugs if the plugs are right for the engine. If you have to avoid doing something while to drive to keep a piston from hitting a plug then you need a new engine. If you dropped to 2nd at 80, your tires should skid, your clutch might slip, etc, but your piston should not get "sucked" up to the spark plug.
I'm not arguing with what Lew said. He's probably right. But if it's happening on a brand new car it should be driven through the dealership's front window if they don't replace the engine and kiss your ass while they do it so you don't make it well known just how poorly made the motor in your car was.
Hopefully it's similar in Canada, but if you were in the states and your dealer was being a prick I'd tell you to go to the DMV with a complaint and make sure the dealer knows your doing it. Dealerships are licensed by the DMV and if they get enough complaints about a dealer they investigate. The dealer has to shut down while they're being investigated, which isn't good for business and they could be fined, lose their license, etc.
^^That's advice I got from a friend who happened to be a NYS Supreme Court Justice when a dealer was dicking me around.
Is this forum still full of n00bs learning that you can't boost your daily driver on a part time retail income?
BikerFry is offline   Reply With Quote
Old May 11th, 2004, 01:28 PM   #50 (permalink)
in^3,N20,RPM,PSI
James's Avatar
Yeah exactly... who wants to buy a car you can't beat the crap out of without worrying about closing the gap on a piston?
05 Frontier SE CC 4x4 (6spd)
Old May 11th, 2004, 01:44 PM   #51 (permalink)
Powered By hopes & dreams
chimmike's Avatar
chances are likely this kid goes to 55 in 3rd and downshifts to 2nd, prolly snaps the revs to 6500 or so.......you do that to any car with a 6250 rpm redline, you'll prolly slap the piston too.
all dun grow'd up.
only real motored toy left:
'06 GSX-R 1000
'07 Harley V-rod night rod
Old May 11th, 2004, 01:46 PM   #52 (permalink)
in^3,N20,RPM,PSI
James's Avatar
well he hasn't said that he's done that... I mean most ppl on this forum put the pedal to the metal all the time and never have to worry about this problem... it is a design problem if you have this problem...
and even if he over reved his motor by downshifting into 2nd at 60 unless the connecting rods break I cannot see how the piston should ever contact the plug... maybe destroy a few items in the cylinder head.
Old May 11th, 2004, 03:11 PM   #53 (permalink)
Nissan Fanatic
I'm guessing this engine is out of spec from what it should be. The ONLY way to over rev this engine is to down shift to too low of a gear from a higher gear. A easy mistake to make on a BMW M3 with Gods tranny and very close gears on the shifter. On our car, the tranny is notchy enough as it is. I don't see how a miss shift could be made.
Even with a miss shift, you would get valve floating. I've never heard of piston floating before. The crank, rods, and pistons shouldn't be able to strech like that. That engine just must be out of spec or something. Either the deck of the block isn't high enough, or the head was shaved down too far. Something isn't right and spark plugs hitting a piston is far from normal.
caveman is offline   Reply With Quote
Old May 11th, 2004, 06:53 PM   #54 (permalink)
man what is your problem. i know how to drive. why do u keep saying this kid does this wronge, and he does that wronge. the most i ever downshifted too was maybe 4500. this motor is still new only like 6000 miles. and i do know how too brake in an engine, so save ur time and dont say that.
sucking sound when preparing to change spark plug labradort Frontier 5 Feb 6th, 2007 09:50 PM
Oil in spark plug sleeve... 9double8 SR-Series Engines (DE/VE) 6 Jul 22nd, 2006 05:34 PM
spark plug wires?? lotus197 GA16DE 1.6L Engine 19 May 6th, 2004 02:19 PM
question about spark plug wires lotus197 B13 91-94 chassis 4 Sep 17th, 2003 10:34 AM
Tried the nos........ wglenn B14 95-99 chassis 34 Dec 4th, 2002 05:09 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
