Old Mar 16th, 2004, 09:28 AM   #1 (permalink)
SE-R4ME
NISMO CAI Intalled....suspect problems
Installed NISMO CAI, drove about 200 miles, then SES light and "limp" mode to my garage. I suspect MAS problem. Are the symptoms in line with that problem? Advise, solutions, help!
SE-R4ME is offline   Reply With Quote
Old Mar 16th, 2004, 09:31 AM   #2 (permalink)
vector03
And justice for All!!!
vector03's Avatar
Send a message via AIM to vector03
Yeah that sounds about right.....check to make sure the MAS is plugged back in all the way. Check around the board. This problem has been posted a lot of times.
-Greg
"For the last time Token, you're Black. You can play Bass Guitar."
My Ride
HPAutoWorks
Stemar MotorSports
vector03 is offline   Reply With Quote
Old Mar 16th, 2004, 09:44 AM   #3 (permalink)
SE-R4ME
"Check around the board." I'm ignorant here. Last car I got my hand dirty on was a '65 Mustang. Clue me in here. Thx.
Old Mar 16th, 2004, 09:45 AM   #4 (permalink)
tekmode
specV Addict
tekmode's Avatar
Send a message via AIM to tekmode
use the search button and search for CAI.....it's most likely your MAF is put on backwards or something not plugged back in all the way
2006 Superblack Altima SE-R
HPautoworks
tekmode is offline   Reply With Quote
Old Mar 16th, 2004, 01:03 PM   #5 (permalink)
Ruben
Friends of ours...
Ruben's Avatar
Send a message via AIM to Ruben
Check all the connections, with the negative terminal on the battery undone, and then clear the ECU.
Although limp mode, usually requires a trip to the dealer.
Ruben - O.G. Club Mofo Mobster
2003 Chevrolet Corvette Z06
The Z06 / Z06 Replaced 350z / 350z Replaced Spec V / Spec V Replaced 3.5 AltimaSE
Ruben is offline   Reply With Quote
Old Mar 16th, 2004, 02:18 PM   #6 (permalink)
YELLOWV
YELLOWV's Avatar
Sounds like the MAF is backwards or you damaged it while doing the install.
05 Titan King Cab SE
Banks Exhaust, Volant Intake
YELLOWV is offline   Reply With Quote
Old Mar 16th, 2004, 11:48 PM   #7 (permalink)
Silvspec86
Nissan Addict
Silvspec86's Avatar
no...doesnt sound like you put it on backwards if you drove it for 200 miles with no problem, if you put it on backwards you would have had it immediatley. its probly damaged or fried or the connection came loose. play with it, check around and try different things as mentioned above. get it fixed quick er else you wont be going anywhere above 3,000 rpm.
Injen RD CAI, Greddy Evo2 Exhaust, Yokohama AVS ES100's, Hotshot header, '03 Tranny, Energy Motormount Inserts, Nismo Lower Tie-bar, Nismo Rear Sway Bar, EBC GreenStuff Pads - http://www.cardomain.com/memberpage/590852
Silvspec86 is offline   Reply With Quote
Old Mar 17th, 2004, 06:45 AM   #8 (permalink)
SE-R4ME
Question
Went back under the hood, checked connections, made sure the MAS housing was installed in the right direction (i.e., air flow towards the engine intake)...don't recall dropping or touching the sensor itself...I mean it is pretty protected withing the housing.
If blown, would it be visible to visual inspection?
Lastly, blown MAS seems to be a recurring problem with CAI's. What's the solution? Is there a "high performance" MAS available that would handled the environment presented by the CAI?
Old Mar 17th, 2004, 09:37 AM   #9 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
the MAF could have blown due to your mishandling of it. I had a MAF blow because it bounced when I hit a bump in the road. And no, there's no way it's visible for visual inspection. Very sensitive unit.
It's not really a recurring problem, one way or another it comes down to one of two things 1)faulty piece (much less likely) and 2) handler error (the main cause).
no, there's no high performance MAF (it's MAF, not MAS) available.
My Website, check it out!
Old Mar 17th, 2004, 10:23 AM   #10 (permalink)
SE-R4ME
This could be an expesive fix. MAFs aren't cheap.
Old Mar 17th, 2004, 11:48 AM   #11 (permalink)
chimmike
chimmike's Avatar
you got that right. New from Nissan it's something like $500-600.
Old Mar 17th, 2004, 11:55 AM   #12 (permalink)
Ruben
Friends of ours...
Ruben's Avatar
If you have to get a new one, check www.car-parts.com, I just searched and found them starting at $75.
Just Installed. Nismo Cat Back and Nismo CAI Blue2003SpecV QR25 2.5L Engine 7 Mar 2nd, 2004 12:37 PM
nismo vs aem cai UofS bolts35 QR25 2.5L Engine 2 Dec 3rd, 2003 07:39 PM
Picture of Nismo CAI tekmode QR25 2.5L Engine 39 Sep 16th, 2003 04:39 PM
Intalled Cai Now Battery Light And Brake Light Are On?!? Magicman520 GA16DE 1.6L Engine 8 Sep 10th, 2003 06:44 PM
CAI problems NW200sx GA16DE 1.6L Engine 6 Apr 5th, 2003 03:23 AM
