Old Aug 4th, 2002, 09:45 PM   #1 (permalink)
DrMoussaka
Posts: n/a
Will this work?
I was thinking about getting an MSD Ignition so i could have the varaity of the extra rev limiter when im racing down the 1/4. This way i could launch at the same rpm every time
Will this one work for the spec V?
http://www.jegs.com/cgi-bin/ncommerc...43&prmenbr=361
Old Aug 14th, 2002, 11:25 AM   #2 (permalink)
red SE-R
red SE-R's Avatar
Send a message via Yahoo to red SE-R
i dont think it will work due to two reasons first nissan uses coil over plug design ignition IE: four coils. the MSD DIS-2 Ignition (For Use On 4-cyl Engines with 2 Coil Packs). . and second unless you plan on replacing the springs and valves i would not push past the rev limit set by the ecu.
Smeeeeeeeeeeg Heeeeeeead
red SE-R is offline   Reply With Quote
Turn signal does not work after a few minutes of running calfaro General Discussion 6 Aug 27th, 2003 06:16 AM
Rear left speaker won't work on my b13 B132nr B13 91-94 chassis 4 Mar 30th, 2003 10:54 AM
Blew something on the way to work NeonLVR E/CA-Series & GA16i Engines 7 Jan 22nd, 2003 11:01 AM
90 Pathfinder Lights & Cruise don't work Nick Rivers Truck & SUV 3 Dec 26th, 2002 11:23 PM
