Old Aug 5th, 2003, 11:14 PM   #1 (permalink)
RotorSpec
RotorSpec's Avatar
Send a message via Yahoo to RotorSpec
Question Check Engine light
I just put an AEM short ram intake on my car 3 weeks ago. My check engine light just came on today. Has anyone who has put an intake on your car encounterd the same problem? I think that it has something to do with the MAF sensor.
RotorSpec
RotorSpec is offline   Reply With Quote
Old Aug 6th, 2003, 05:03 AM   #2 (permalink)
cortrim1
Nissan Fanatic
cortrim1's Avatar
Re: Check Engine light
I would check all the connections on the maf and the aem intake. The maf on this car is very sensitive I have heard that a short ram intake will some times cause a check engine light. As long as the car does not go into limp mode you should be ok.
:thumbup:
02 spec (173.1whp,178.9lbft)retired
94 se-r (342whp, 289lbft @15psi)
92 se-r (sr20ve with N1 cams DD)
www.cardomain.com/id/cortrim1
cortrim1 is offline   Reply With Quote
Old Aug 6th, 2003, 05:46 AM   #3 (permalink)
tekmode
specV Addict
tekmode's Avatar
Send a message via AIM to tekmode
Did you unhook the MAF when you installed it?
2006 Superblack Altima SE-R
HPautoworks
tekmode is offline   Reply With Quote
Old Aug 6th, 2003, 11:10 AM   #4 (permalink)
cortrim1
Nissan Fanatic
cortrim1's Avatar
that will do it every time if the battery is connected
:thumbup:
Old Aug 6th, 2003, 11:15 PM   #5 (permalink)
RotorSpec
RotorSpec's Avatar
Why did it take so long to turn on? It has been like three weeks. I did unplug the sensor while the battery was hooked up.
By the way, does anyone know where I can buy the AEM extension so I can turn my short ram into a cold air intake? I think that all I need is that inlet tube.
RotorSpec
Old Aug 7th, 2003, 04:56 AM   #6 (permalink)
cortrim1
Nissan Fanatic
cortrim1's Avatar
you can get it from any aem dealer, but you will have better luck getting it directly from aem. As for your check engine light I would go to autozone and get the code reset. Make sure to find out the code number. there is a list of the codes on www.b15sentra.net that will tell you what the code means.
:thumbup:
