Old Jul 11th, 2002, 12:55 PM   #1 (permalink)
red SE-R
red SE-R's Avatar
Send a message via Yahoo to red SE-R
variable intake system
I have a question on the variable intake system, it opens the second set of runners at 4800 to 5000 and with the 6250 redlineits kinda short. isnt there a way to make it open sooner? I used to have a 86 toyota carolla gt-s with (tvis tuned variable intake system) thats where honda got the idea on the integra gsr and now nissans qr25 motor. I found that by putting a smaller vacuume pot on it it opend quicker and sooner, but i havent been able to get much info on nissans variable intake system. to see if this same method would work to get the second set of runners to open a tad sooner getting more air into the engine. thus more power...
on the toyota it orriganally opened at 6 with a redline of 8 after i swapped the dashpot for a smaller one it opened at 4600 and really made a difference.
hopefully there will be a way to do this with the qr25 cause once the second runners opens it just really comes to life!
Smeeeeeeeeeeg Heeeeeeead
red SE-R is offline   Reply With Quote
Old Jul 11th, 2002, 01:49 PM   #2 (permalink)
cortrim1
Nissan Fanatic
cortrim1's Avatar
Talking INTAKE RUNNERS
you can make the second set of intake runners stay open all the time by zip tying the butterfly valve open. Its on the drivers side look down the fire wall and you will see a rod with a pivoting clamp on on side. push the clamp forward until it hits the stopper then zip tie.
:thumbup:
02 spec (173.1whp,178.9lbft)retired
94 se-r (342whp, 289lbft @15psi)
92 se-r (sr20ve with N1 cams DD)
www.cardomain.com/id/cortrim1
cortrim1 is offline   Reply With Quote
Old Jul 11th, 2002, 02:49 PM   #3 (permalink)
BlackoutSpecV
Nissan Addict
BlackoutSpecV's Avatar
you should note that my doing that you would be keeping your short runners open all the time, thus killing your low-end. I would say that as with honda motors, there will be after market valve controlers soon that you can hook to the motor/ECU and manualy change the setting based on driving condition. With the revlimiter at a weak 6100 rpm you want to have all the low-end you can get.
-- 2002 SE-R Spec V
BlackoutSpecV is offline   Reply With Quote
Old Jul 11th, 2002, 04:35 PM   #4 (permalink)
red SE-R
red SE-R's Avatar
i dont want them open all the time just to open sooner like around 4K instead of 5K thats what im shooting for.
Old Jul 11th, 2002, 04:43 PM   #5 (permalink)
lbcklik1486
Posts: n/a
Dude, i just wanted to say that hachi roku's kick ass!!!!!! long live the 86!
Jason
Initial D style
Old Jul 11th, 2002, 04:53 PM   #6 (permalink)
red SE-R
red SE-R's Avatar
i loved that car i put the wide body kit on it from trd after market cams, forged crank rods and pistons, total seal rings, garrett t3/t4 hybrid turbo @ 12psi with intercooler, boost controller, custom exhaust system, mallory ignition, eibach sportline springs and koni shocks and struts. superchips ecu upgrade with the rev limiter reset to 10K. And the best part it was the coupe version rear wheel drive with a 5 speed so it loooooved to do donuts
Old Jul 12th, 2002, 06:06 AM   #7 (permalink)
cortrim1
Nissan Fanatic
cortrim1's Avatar
Thumbs up INTAKE RUNNERS
The intake runners are controled by pressure not by the ecu. If look at the actuator you will see it is mechanical, thus no wirers and no ecu mod. As for losses I know several people who have done this the only down side is bad gas milage because both runners are open at the same time. It does help acceleration one person running a 50 shot ran a 13.9x on the stock tires
search: b15sentra.net
:thumbup:
Old Jul 12th, 2002, 09:16 AM   #8 (permalink)
BlackoutSpecV
Nissan Addict
yea, wow...
thats what a long day of work will do to you, i was off on valve timing.... BLAH
Okay so no more mid-day work postings.
-- 2002 SE-R Spec V
Old Jul 12th, 2002, 11:09 AM   #9 (permalink)
cortrim1
Nissan Fanatic
cortrim1's Avatar
Originally posted by BlackoutSpecV
yea, wow...
sorry I though you wanted to know about the intake itself.
Yes the car could benefit from some ecu tuning and some new cams and valve springs. JWT has prototype cams and I would not be surprised if they were working on the ecu
:thumbup:
Old Jul 19th, 2002, 09:59 PM   #10 (permalink)
ezcheese15
Send a message via ICQ to ezcheese15 Send a message via AIM to ezcheese15 Send a message via MSN to ezcheese15 Send a message via Yahoo to ezcheese15
Re: INTAKE RUNNERS
Whoa....I gotta correct you on this. They *ARE* controlled by the ECU. The ECU has one wire that goes to the intake runners. The Runners are mechanical, however, they are controlled electronically. The ECU sends a 12V signal to the intake runners at all times when the RPM is under 5000. At 5000rpm, the ECU cuts the 12 V signal to the intake runners, which allows the system to apply vacuum to the solenoid, which in turn moves the plunger and changes the runners.
I am currently working on a setup to have the runners switch at a different rpm using a switch. I can get it to work but can't get the RPM right. The switch seems to have a mind of it's own. But I'm working on it, and will post results when I get it figured out.
Torry
Torry
02 Spec V
ezcheese15 is offline   Reply With Quote
Old Jul 21st, 2002, 08:54 PM   #11 (permalink)
Black Spec V
Posts: n/a
unfortunately i dont think that will matter man....the intake manifold is coming out soon, it will eliminate that shit...
Old Jul 22nd, 2002, 06:15 AM   #12 (permalink)
cortrim1
Nissan Fanatic
cortrim1's Avatar
Re: Re: INTAKE RUNNERS
Torry
thanx for the info torry
:thumbup:
Old Jul 22nd, 2002, 11:27 AM   #13 (permalink)
BlackoutSpecV
Nissan Addict
I'm lost, after market intake manifold?? or are you doing a custom ob?
-- 2002 SE-R Spec V
Old Aug 4th, 2002, 03:49 PM   #14 (permalink)
KSipmann
Banned
KSipmann's Avatar
A note about the butterfly valves: Yes, you can make the manifold run at max volume all the time by zip tying the cable to the actuator open, however you won't notice any performance gains (realistically you should get less low end torque).
It's meant to be there for a reason. If you disconnect it, the intake will function more like a regular multi-valve intake. Your basically creating a fixed geometry intake manifold by doing this mod. If the butterfly valves are tied to be left open partially or all the way, your creating a slower charge motion, which means the flame spreads slower, resulting in sluggish burn rates and lower engine output.
And since the actuator is controlled by vacuum pressure and ECU, wouldn't you think that by modifiying it to stay partically or fully open, that it may send a different signal back to the ECU causing you some problems?
As for the switch idea, I don't think it'd be beneficial personally, not very practical for a daily driver. If your in the middle of a race, you need to be focusing on the road. Not to mention human error, I mean if you don't flip the switch at the correct time, your forcing your engine to breath through a restricted intake setup at high RPM's. That spells lower engine output.
This of course is just my 2 cents...
KSipmann is offline   Reply With Quote
Old Aug 4th, 2002, 04:56 PM   #15 (permalink)
ezcheese15
The switch I had installed was electronically actuated by a signal off the crankshaft position sensor. You can select the RPM you want it to activate at beforehand. You don't "flip" the switch when you want it on. It is completely automated. All it is doing is changing the switch point on the car. Stock it switches at 5000 rpm. The switch will make it switch at any RPM that you select. So let's say you put in 4000 RPM. Then the switch switches at 4000 RPM automatically. You don't have to "think" about anything.
The idea of the switch is not to gain more peak HP or Torque. It is to gain more HP lower in the curve. Between 4000 RPM and 5000 RPM, if the secondaries were open, you would make more HP between those points, and roughly the same torque. I don't know exact numbers until I dyno. But the point is, down low you are not changing the torque or HP, and up top you are not either. This is middle range stuff you are changing. And it *is* an increase, I swear. I guess I'll have to dyno to show actual numbers. But I swear it will work they way I picture. Right now I have to wait to get a new switch though, one that is not defective
Torry
02 Spec V
Pro 1 performance intake system waijai[g35coupe] Z33 350Z 2003+ 1 Oct 21st, 2003 12:40 AM
Custom Intake glowsentra B13 91-94 chassis 21 Aug 19th, 2003 06:10 AM
Intake system for 1996 sentra Onewheelup11 General Discussion 2 Mar 9th, 2003 09:12 PM
What is the deal with the variable intake Chrisbrd43 QR25 2.5L Engine 4 Sep 19th, 2002 12:53 PM
intake system ferreras B13 91-94 chassis 2 Aug 9th, 2002 04:36 PM
