fuel pump problem??? please help - Nissan Forums: Nissan Forum
» Auto Insurance
» Featured Product
Go Back   Nissan Forums: Nissan Forum > Nissan Models > Sentra, Pulsar, NX, B14 200SX > QR25 2.5L Engine
Register Home Forum Gallery eBay Marketplace Insurance Active Topics Garage Search Today's Posts Mark Forums Read Auto EscrowAuto Loans
NissanForums.com is the premier Nissan Forum on the internet. Registered Users do not see the above ads.
Old Aug 14th, 2009, 05:07 AM   #1 (permalink)
ok so i go out to start my car and i dont hear the humming noise of the fuel pump turning on when i turn the key, and of course the car wont start. i use a voltmeter to see if i have power to the pump, and i do. so my old american car knowledge tells me the fuel pump is no good. the dealer replaced one at 45k and now im at 90k so i think "ok i guess these things only last 45k" and i go get one from the dealer. wow these things are $400, but ive never been able to change a fuel pump in 15 mins before. wow this trap door thing is great. turn the key and still no humming noise. if anyone has any ideas id really appreciate some help. thanks
oh yea and i guess i might have a fuel pump relay, but if i do its not marked. autozone will sell me one, but my local import parts store says my car doesnt have one??????
2002 sentra specv
lvspecv is offline   Reply With Quote
Old Aug 14th, 2009, 05:53 PM   #2 (permalink)
you can always unhook the quick connect part of the fuel line (thats located off the firewall on the drivers side). turn the key on for a split second and see if anything comes out. If nothing is coming out, then your pump is not working.
jubjub93 is offline   Reply With Quote
Old Aug 14th, 2009, 06:07 PM   #3 (permalink)
Nissan Addict
pulsar86's Avatar
There should be a pump relay somewhere. Check owners hand book for location. Or might be as simple as bad earth on pump. Try earthing pump with jumper wire. Be careful that you relieve fuel pressure before disconnecting fuel lines and be extra carefull running pump with line off [big fire risk]!
Aussie 1986 N12 PULSAR 24 years,250000km one owner, still going strong!
pulsar86 is offline   Reply With Quote
Old Aug 15th, 2009, 11:47 AM   #4 (permalink)
Well Dont try to start the car with an end disconnected. You only need to rock the key forward for a split second. Have a buddy watch the hose to see if any fuel comes out (stand back so non get in your eyes), just a split second should cause a gush, i know its the backyard way of doing it, but its simple and fast.
I wish somebody has a wiring diagram for the fuel pump.
I get 11.7v from one wire and 4.8v from another while the key is forward.
I figure the two black wires are grounds.
Just wondering what the other wire is for.
Old Aug 16th, 2009, 11:46 PM   #5 (permalink)
lvt
lvt's Avatar
Maybe it's a signal wire so that the car's computer can monitor the RPM of the fuel pump.
lvt is offline   Reply With Quote
Old Aug 18th, 2009, 08:02 PM   #6 (permalink)
huh?
well thanks for the suggestions guys, but i brought it to the shop. now i dont feel so stupid cuz the shop says all signs point to a bad fuel pump, but thats not the problem. they've been on the car all day and they cant figure it out either. all they said was maybe the computer is bad, they want one more day to diagnose but said ill probably have to take it to the dealer. that shop its at specailizes in toyota, anyone know of a good nissan tech in las vegas?
Old Dec 17th, 2009, 11:10 PM   #7 (permalink)
noo nooo no
ok first of all... the stock fuel pumps suck cock :-| just to put that out there. everyone I know with a spec v has had an issue with it. replace it asap ... you will start to have more an more problems with it... I replaced mine when I bought my car because i was having the same problem as you. car would stall when starting... wouldnt start... would put out on me... same shit... 100 bucks for a 255walboro pump ... throw that shit in... promise it will make ur life a lot better.. no more sitting in a parkin lot havin people lookin at u like wtf what a pos... its not none of the connectors or nothing they are just shit... period. my buddy did the same thing..replaced his with the stock one at the dealer.. for a few hundred an had the same problem about 20,000 latter... good luck bra
Red-Spec-V is offline   Reply With Quote
Old Oct 29th, 2012, 04:52 PM   #8 (permalink)
Florida02SpecV's Avatar
Having the same issues, any updates from this would be great!!
Here is my thread in if you want to post over in there - http://www.nissanforums.com/qr25-2-5...g-02-qr25.html
Florida02SpecV is offline   Reply With Quote
Old Nov 16th, 2012, 05:01 PM   #9 (permalink)
I'm in a similar boat with an '04 2.5L Sentra.
The pressure regulator was leaking causing start up issues, especially after sitting for more than 30 minutes, especially on a hot summer day. It would only hold pressure for about 15 seconds.
I replaced the fuel pump module, which worked great for a few days, and now I think this one is leaking too. The new one is an airtex pump module, I still need to test it and confirm :mad
For you experts, what are the fuel "rest" pressure specs?
Ie: how many minutes above how many psi?
epmedia is offline   Reply With Quote
Old Nov 17th, 2012, 05:54 AM   #10 (permalink)
thanks for all the information guys
blesak is offline   Reply With Quote
Old Nov 17th, 2012, 06:41 AM   #11 (permalink)
chuckster57's Avatar
The 4.8V is probably for the fuel gauge sending unit.
Although I don't drive a Nissan, I do work on them.
DD is a 2005 Honda Accord and my Work horse is a 1994 Ford F350,CC,LB,DRW with a 7.3 IDI diesel engine.
chuckster57 is offline   Reply With Quote
BB code is On
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
