Old Oct 19th, 2006, 12:51 AM   #1 (permalink)
dpg24m
injen cai problem
hey i have a 03 spec v sentra and last night i installed a cai from injen now my idle is high and my engine light is on and yes i did have battery disconected during the install please help!!!
dpg24m is offline   Reply With Quote
Old Oct 19th, 2006, 05:48 AM   #2 (permalink)
saint0421
Nissan Fanatic
saint0421's Avatar
Send a message via MSN to saint0421 Send a message via Yahoo to saint0421
First find out what code your throwing. Did you mess with the throttle body at all? If it's a P0507. Try doing the Idle Air Volume Relearn.
1. Perform "Accelerator Pedal Released Position Learning".
2. Perform "Throttle Valve Closed Learning Position".
3. Start engine and warm it up to normal operating tempurature.
4. Make sure all prep items are completed before moving on.
5. Turn ignition "OFF" and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch "ON" and wait 3 seconds.
7. Depress and release the accelerator pedal 5 times within the next 5 seconds.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approximately 20 seconds until the "SERVICE ENGINE SOON" light stops blinking and turns on.
9. Fully release the accelerator pedal within 3 seconds after the SES light goes off.
10. Start engine and let idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed is within specifications. (700+/-50 RPM unless you had it altered.)
13. If idle still doesn't work right, curse and spit because you gotta start over. Check the following 3 before starting over: throttle body is closed when the vehicle is off, PCV works in stock form, and no intake manifold leaks
So. . . Your face is dumb!
saint0421 is online now   Reply With Quote
Old Dec 17th, 2006, 05:32 PM   #3 (permalink)
habenero2002
If the battery was disconected for over an hour Idle air volume relearn has to be performed
habenero2002 is offline   Reply With Quote
Hotshot CAI nelam Buyer & Seller Feedback/Ratings 0 Oct 14th, 2005 01:38 AM
Help with Injen CAI ShiftySE-R SR-Series Engines (DE/VE) 6 Jun 9th, 2005 01:40 PM
WOO-HOO...Injen CAI Is On!!!! ALTYHOLIC L31 2002 - 2006 39 Mar 24th, 2004 07:05 PM
HS CAI Problem UPDATE: se7enty7 B14 95-99 chassis 2 Apr 7th, 2003 11:57 PM
Good info on CAI vs WAI Ruben L31 2002 - 2006 1 Mar 4th, 2003 01:00 AM
