werd, when using lower grade gas, you'll hear valve chatter... meaning that less than 91 gas and the spec dont get along too well. It says in your user manual
__________________ Its not what you know, its who you know
05 Brilliant Aluminum Spec V - ES MMI's Recieved! pending install
04 Blackout Sentra 1.8s! = stock = Traded in 06/27/05! http://myspace.com/rv_jd MYSPACE PROFILE PAGE
a lot, especially on the 2002-2003. 91+ is needed. if you have an 02, 93+ would be ideal. the manual specefically states to run premium and if you run regular to not drive over 3000 RPM and to mix it with premium.
at 13 gallons, your looking at spending an extra 2.60$ per fill up from empty.
I've put 93 in all but once, and thats because where I was only had 92, but I just put in 2 or 3 gallons to get me back so I could run 93 back in it.
__________________ SE-R SpecV
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety. - Ben Franklin
Ive never run anything besides medium (89) on my 04, and never had a problem.
Sun Burst 04 Spec-V: Gen II Nismo CAI - Megan Racing header - IM Pulley - JWT Cams - Motor Mount Inserts - HPA Downpipe - Apex'i WS2 - Faktion Gen2 Short Shifter - Custom Lip - Tinted Windows
I run 93 on mine only. Not comfortable putting in a lower grade into it. Just like previously stated, don't be cheap....it costs and extra 3 bucks or so to fill up a tiny 13 gal tank
Im not cheap, but I dont see any reason for anything higher than 89 if I havent had a problem. Of course, my car is nowhere near old and hasnt seen the test of time (several years) of running on 89, but its been working, so ill keep it as that. Any even if its 3 bucks on a 13 gal tank, its 3 bucks everytime
Yeah, I forgot to mention. Cause it was pointed out that you really do need 93 with 02/03.
