Originally Posted by chimmike
well after research, the SR20 one will not work on the QG. different starter gear and different bolt specs.
Save up yer dough and pick up the UR, it's a nice unit
Sorry to be a pain in the ass but can I get you to PM me the source of your information and any other relevant info.
Its just that i had this article pointed out to me:
http://www.nissanperformancemag.com/...keithmay02.php
See the following quote at the bottom:
Both the SR20DE and QG18DE use the same clutch and flywheel configuration. See below:
Disc Specifications:
Outside Diameter: 8 7/16"
Spline: 13/16"
Teeth: 18.00
Flywheel Type: Step
Inches: 7.0e-03
Millimeters: 0.18
The UR unit was originally made for the SR20DE, but it bolts directly into the QG18DE with no problems or modifications
