Old Nov 3rd, 2002, 05:37 PM   #1 (permalink)
e2001gxe
Send a message via AIM to e2001gxe
HS Cold Air Intake
Has anyone had problems with stalling after installing the HS intake? I have the HS header and just installed the intake yesterday. If the engine is cold it usuallys idles high so it doesn't stall. However when it's been running for a while (like I'd stop to get something then start it back up), the idle drops very low (below 500, seems to be the cutoff) it'll stall. Any ideas on how to remedy this?
-Eric
edit: Here is a picture of the intake, but it's almost 900k so broad band only.
2001 GXE CV2-H
e2001gxe is offline   Reply With Quote
Old Nov 5th, 2002, 01:04 AM   #2 (permalink)
e2001gxe
Someone on b15 mentioned somthing about an AAC valve or something. Any ideas?
2001 GXE CV2-H
Old Nov 5th, 2002, 09:50 AM   #3 (permalink)
pdid11
Posts: n/a
http://www.se-r.net/faq/problems.html
This was posted somewhere I found it on www.ask.com it is regarding the SR20DE but they talk about the AAC, there is some good responses.
From what I have read the AAC seems to be a Nissan thing, other companies must call it something different.
You might want to try this:
http://www.se-r.net/engine/adjust_idle.html
OK last one, promise. This pic shouold help show where things are it is the 97 GA16DE but th setup of the engine LOOKS very similar to ours.
http://www.autotechonwheels.com/tech...d_no_start.jpg
Old Nov 27th, 2002, 06:28 PM   #4 (permalink)
ca02XE
HS CAI
installed it yesterday and very impressed. only question is the purpose is to get cooler air into the motor. the metal pipes used in almost every CAI will heat up as the motor does. this will heat up the air passing through the pipes.
doesn't this defeat the purpose????
to solve this problem GM has gone to plastic intake pieces, even the manifold. the plastic LS6 manifold is better than aluminum aftermarket manifolds.
shouldn't the CAI use plastic pipes or some other material that will not heat up as fast??????????
ca02XE is offline   Reply With Quote
Old Nov 27th, 2002, 08:44 PM   #5 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
actually no, plastic heats up faster than the metal. The metal looks better, and has better structural rigidity.
My Website, check it out!
