Old Jan 21st, 2005, 05:16 PM   #16 (permalink)
sr20dem0n
^ ownz you all ^
sr20dem0n's Avatar
Send a message via AIM to sr20dem0n
well I don't know how much the intake valve is, but I doubt it's $500
the MAF is $500 from the dealer, and I got it for $200 through another shop. It was an OEM Nissan MAF, brand new, exactly like what you would have got through the dealer. So assuming the intake valve accounts for the other $200 from the dealer, you could probably get the pair and install them yourself for $3-400 or so
My Site
For Sale: Elemental Designs e12a (local only), PM for details
sr20dem0n is offline   Reply With Quote
Old Jan 21st, 2005, 05:24 PM   #17 (permalink)
lexiSentra
Is it hard to do?
lexiSentra is offline   Reply With Quote
Old Jan 21st, 2005, 05:29 PM   #18 (permalink)
sr20dem0n
^ ownz you all ^
sr20dem0n's Avatar
the maf couldn't be easier
not sure about the intake valve
My Site
Old Jan 21st, 2005, 05:30 PM   #19 (permalink)
BadBoy91
BadBoy91's Avatar
The MAF your man could probaly replace, but the intake valve will require a skilled pro to replace it properly. is the dealer charging $700 for parts alone or does that cover labor also?
chirp chirp chirp, chiirrp, Screeeech, SMASH!-- buy good tires.
BadBoy91 is offline   Reply With Quote
Old Jan 21st, 2005, 05:30 PM   #20 (permalink)
lexiSentra
parts and labor for $700
Old Jan 21st, 2005, 05:39 PM   #21 (permalink)
BadBoy91
BadBoy91's Avatar
that honestly seems like a fair deal, the valve isnt an expensive part but would be labor intensive to repalce, and the MAF is an exspensive part that is cheap (labor wise) to repalce. Do you know how many Hours of Labor they quoted?
Old Jan 21st, 2005, 05:48 PM   #22 (permalink)
BadBoy91
BadBoy91's Avatar
you shouldnt get charged for more than 10hrs labor at most any thing mor and you would be gettin ripped
Old Jan 21st, 2005, 06:38 PM   #23 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
have you had the crank position sensor recall done? I'd get that checked first.
My Website, check it out!
Old Jan 22nd, 2005, 06:51 PM   #24 (permalink)
rselah25
Send a message via AIM to rselah25
this same situation happend to me down here in FL....i installed a CAI, and all of a sudden a month later my car stalled out at 60mph....i got it towed to goodyear and it ended up costing around 600$ for everything (maf only and labor) the maf costed like 500....so i prolly got ripped off ohhh well....but yea make sure you air filter is on tight....i mean TIGHT....tight to the point where you cant pull it off easily....
zerotype ..!..
rselah25 is offline   Reply With Quote
Old Jan 22nd, 2005, 07:07 PM   #25 (permalink)
chimmike
chimmike's Avatar
whether the filter is tight or not doesn't matter a damn
if the whole assembly can bounce around, you're fuct.
EGR Flow and Knock Sensor aaronford Truck & SUV 6 Nov 25th, 2004 11:43 PM
Message from your friendly Moderator mastertech Truck & SUV 5 Nov 5th, 2004 03:05 PM
air flow meter ? trer General 240SX/Silvia/S12 200SX 0 Jun 15th, 2004 08:14 PM
bad air temperature sensor?? ethan666 SR-Series Engines (DE/VE) 4 May 22nd, 2003 12:08 PM
Mass Air Sensor VTEC_THIS QR25 2.5L Engine 3 Oct 8th, 2002 04:48 PM
