Old Dec 15th, 2004, 06:46 AM   #1 (permalink)
blackrex
blackrex's Avatar
Car Dies At Idle???
Hi All,
My QG16DE engine seems to die off at idle after it has warmed up. This happened after I went for a long cruise of 160km/hr for a covered distance of 1000+km. Have brought the car to the local mechanic and he had plug the oil breather tube that is connected to air filter funnel, so now the engine oil gas is dissipated into the atmosphere. His claim is that, my piston rings may have worn, and the excess gases that seeped through has caused the trottle body to cause the constant idle problems. Is this true. So far after doing this, the engine has yet to die at idle, but it still fluctuates to below 500rpm at idle, and then rises again. Pls help.
Thanks,
Seven
blackrex is offline   Reply With Quote
dies if it drops to idle? sentra97gxe GA16DE 1.6L Engine 12 Jan 2nd, 2005 12:44 AM
88 Sentra will not idle, Please Help! jstollfu B11/B12/KN13 82-90 chassis 7 Nov 19th, 2004 08:28 AM
Adjusting idle on '91 sentra SE-R bast525 SR-Series Engines (DE/VE) 2 Jul 4th, 2004 09:34 PM
SR20DET starts right up, but if I let it idle, it bogs then dies beefcake6681 SR20DE/DET Engines 4 Jun 30th, 2003 06:43 PM
Idle problems grray E/CA-Series & GA16i Engines 9 Apr 17th, 2003 11:03 AM
