Old Nov 1st, 2004, 02:08 PM   #1 (permalink)
jeb
2000 Sentra oil filter location?
I can't seem to locate the oil filter on my daughter's new (used) Sentra.
Where the heck is it?
Thanks.
jeb is offline   Reply With Quote
Old Nov 1st, 2004, 05:23 PM   #2 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
on the back of the block, almost directly above and to the passenger side of the exhaust.
My Website, check it out!
Old Nov 12th, 2004, 01:36 AM   #3 (permalink)
chrisCJ
I found that you need to clean the oil off every time. The oil burns and smells real bad. O, You need to get under the car to get to it.
chrisCJ is offline   Reply With Quote
Old Nov 12th, 2004, 10:22 AM   #4 (permalink)
chimmike
chimmike's Avatar
yup...there's no other way
unless you have thin gorilla arms.
Old Nov 12th, 2004, 08:26 PM   #5 (permalink)
tony22r
Longer SER oil filter fits.
Yeah you can say That again chrisCJ ! Two days after my oil change and my car *still* smells of burnt oil, nasty. You're right, only way is from underneath the car. I've seen worse though.. Honda Civics locate their oil filters in a similar location, albeit right *above* the catalytic converter.. OUCH!
So I was at Walmart picking out my oil filter on their little computer thing; and I noticed the oil filter for the SER was longer...
Fram PH6607 $4.48 @ Walmart (for 1.8L QG18DE)
Fram PH7317 $3.97 @ Walmart (for 2.5L SER)
Same outside diameter, same thread pitch & depth, rubber O-rings are identical, only the PH7313 is Longer, and cheaper to boot! More oil capacity so I bought it and installed it during my last oil change. Fits perfect.
Engine now holds like 3.1 qts of motor oil instead of 2-7/8 qts, yippee.
tony22r is offline   Reply With Quote
Old Nov 12th, 2004, 08:31 PM   #6 (permalink)
chimmike
chimmike's Avatar
Fram? NOO!!!! don't use fram!!!
K&N or Mobil 1 or stock, at least.
Must drain oil to put on new oil filter? sweeeems SR-Series Engines (DE/VE) 15 Jul 6th, 2004 08:05 PM
Oil liquid found on air filter bikerbeng GA16DE 1.6L Engine 7 Feb 26th, 2004 12:40 PM
Oil filter dilemma-sr20de vs. vq30de WHITEG20 SR-Series Engines (DE/VE) 7 Nov 29th, 2003 01:52 PM
Recieved Greddy oil filter block for guage senders(info and pics encl.) PatScottAKA99XE GA16DE 1.6L Engine 22 Sep 7th, 2002 08:57 PM
Changing Oil GlowstickBoy Off Topic 5 Aug 8th, 2002 12:07 PM
