Originally Posted by rpaquet
I have the same problem. There ia some related info in the FSM and can send it if you want. Looks like my MAF readings are low based on the FSM but don't know if this is the cause. Would be covered in the basic drivetrain warranty?
that's a good question. if you're in the 3yr 36k bumper to bumper, I'd say yes. however, an O2 sensor is technically a "wear" item, so it's debateable if it is replaceable under the 60k powertrain warranty.
only way to find out is to go to the dealer and post your results!
