Old Sep 8th, 2004, 10:29 PM   #1 (permalink)
b12boi
QG burning rell gas
ok fellers the almera N16 - QG16de burning rell gas (19 MPG). i change the air filter , i check the o2 sensor , did a tune up and still no difference . any suggestions ?
and i carried the car by a electrician to hook up the fog lights and the fellers cant find the fog lights wires . they hook up the harness to the light infront the car but no luck with finding the wires behind the dash . does anyone know where to find it ?
oh and on the highway when the car reach 120km/h it dies down . cant cross 120 km.h
can anyone help me out here ?
b12boi is offline   Reply With Quote
Old Sep 8th, 2004, 10:40 PM   #2 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
1) how aggressive do you drive? Check the spark plugs? have the injectors cleaned.
2) can't help you with the foglight wires...you'll probably need to have them wired to a switch
3) There's probably something wrong somewhere if you can't go faster than 120km/h......check the exhaust manifold gasket for leaks, check all the exhaust for leaks........is the Check Engine Light on?
My Website, check it out!
Old Sep 10th, 2004, 08:42 PM   #3 (permalink)
b12boi
ok i did some digging up and i found out that i need a resistor for the fog lights so that problem is fixed .
Over-drive is on (light does be off ) - would that make a difference because i was told that it would .
i don’t really drive aggressive .would check the spark plugs and injectors tomorrow . the exhaust manifold gasket seems to be ok . no leaks .
Nope the engine check light does not be on .
Thanks for the help /
Old Sep 10th, 2004, 09:54 PM   #4 (permalink)
chimmike
chimmike's Avatar
overdrive on isn't really a big deal....but I'd say maybe just bad gas and hot conditions contributing to poor mileage
Old Sep 14th, 2004, 10:39 PM   #5 (permalink)
b12boi
ok i today i made 160km/h and the car cant go more i am thinking its a electrical problem ??
well i also got 21mpg 2mpg improvement heheh
Old Sep 15th, 2004, 11:01 PM   #6 (permalink)
b12boi
ok i changed the spark plugs today because i was getting a black residue on the muffler tip . Changed the spark plugs from BKR6E to BKR5E-11 . do you all think i would burn less gas because so far it seems like no difference . would i suffer any power loss/gain with the different spark plug ?
Old Sep 15th, 2004, 11:04 PM   #7 (permalink)
chimmike
chimmike's Avatar
I don't know why you'd be running bkr6e's......keep the 5e's in there.
Old Sep 17th, 2004, 11:23 AM   #8 (permalink)
BlackoutSpecV
Nissan Addict
BlackoutSpecV's Avatar
Where are you located? and what kind of gas are you running (like ocatine numbers)?
it sounds like the ill effects of a bad tank of gas, that can stick around for 2 or 3 tanks.
-- 2002 SE-R Spec V
BlackoutSpecV is offline   Reply With Quote
Old Sep 17th, 2004, 08:38 PM   #9 (permalink)
b12boi
ok i am from Trinidad .
running 95 RON but sometimes i run 92 RON .
98 SE-R runs out of gas at 1/4 tank! Help! Gorilla Salad SR-Series Engines (DE/VE) 3 May 5th, 2006 03:41 PM
Fight Gas Prices! Tickwomp Houston Nissan Enthusiasts 19 Apr 15th, 2005 11:02 AM
Don't Buy Gas Tomorow. uncnissan2004 Off Topic 99 May 21st, 2004 01:03 AM
why gas prices have gone so high LIUSPEED Off Topic 10 Aug 27th, 2003 02:19 PM
Idiot Gas Pumping Man (kind of long) UpChuck Off Topic 12 Mar 11th, 2003 01:40 PM
