Old Aug 13th, 2004, 10:05 PM   #1 (permalink)
b12boi
turbo qg - help
ok fellers i have a nissan n16 almera and it has the QG16de engine i think its rated 105hp .......
i was thinking about turbo charging but i have heard the compression is quite high and there is no distributer so its almost impossiable to turbo charge ..
i am accustomed with a turbo vehicle and i need to feel boost .
what you all suggest ?
b12boi is offline   Reply With Quote
Old Aug 14th, 2004, 02:22 PM   #2 (permalink)
dschrier
Nissan Addict
www.mdhall.com
That's for the qg18de, not sure how much different it would be.
dschrier is offline   Reply With Quote
Old Aug 14th, 2004, 02:42 PM   #3 (permalink)
chimmike
Powered By hopes & dreams
chimmike's Avatar
it's not impossible, compression is most likely around 9.5:1.
you have to be smart about it...you can't just slap the turbo on there.
My Website, check it out!
Old Aug 14th, 2004, 07:36 PM   #4 (permalink)
b12boi
if the compression is soo low then i can run about 10lbs easy hmmmmmmmmmm.
interesting .......i never heard anyone turbo a QG15/16 so i am wondering ......
Old Aug 15th, 2004, 04:55 PM   #5 (permalink)
b12boi
ok fellers any more info ???
Old Aug 16th, 2004, 04:19 PM   #6 (permalink)
chimmike
chimmike's Avatar
obviously you don't know what you're doing....so I'll start here:
10psi on what turbo? 10psi on a t3/t4 will blow a QG16DE.
10psi on a T28 should not, ASSUMING you have proper fuel management.
So, with that in mind, I'd like to know how much you know:
What fuel management are you planning to use? What turbo? What manifold? Intercooler? etc.
you can't just throw a turbo on a car...........it is a VERY precise process.......and it does not sound like you have a clue at this point. You've got a lot to learn, so don't spend any money yet...because once you start...you'll realize how expensive it really is.
Old Aug 22nd, 2004, 01:46 AM   #7 (permalink)
b12boi
ok i was planning on using the T25 turbo with a stock silvia/supra intercooler ...going to make a manifold and no idea on the fuel management .....
what you all think ?
how much boost should i run ?
remember i am leaving the car automatic so you all think the tranny would handle the stress of boost ?
am i missing anything ?
Old Aug 22nd, 2004, 10:20 AM   #8 (permalink)
chimmike
chimmike's Avatar
don't make the manifold yourself....you have no idea what you are doing.
www.protech-fabrication.com sells a qg18de manifold, and you'd be dumb not to purchase it.
you still need to worry about recirculating the bov, fuel management, oil and water lines, and downpipe fabrication, along with intercooler piping, etc.....................there's a whole lot more to it than you thing, but I'm not going to walk you through this, and neither is anyone else here, because if you don't know what you're doing....you shouldn't be attempting to piece together a kit yourself in the first place.
Old Aug 22nd, 2004, 06:12 PM   #9 (permalink)
b12boi
ok thanks but i relly wanted to know how much boost i could run with the t25 turbo on the QG16de engine atuomatic .
Old Aug 22nd, 2004, 06:30 PM   #10 (permalink)
chimmike
chimmike's Avatar
with a proper setup, you could run 10-12psi probably.
Old Oct 7th, 2004, 11:08 PM   #11 (permalink)
b12boi
well today i thought was the day i would have had a turbo car again but it seems not .
i gathered all the parts that i need to turbo my nissan n16 QG16de and went to the best turbo expert in trinidad and guess what ............he told me that he is not even going to try to turbo that because if he makes a mistake my engine would go boom !
he said its not worth the risk and i should just swap a sr20det instead . i was quite confused but then again i said to myself that he is the best man in trinidad so he probably knows what he is saying . he say the timing and stuff would be a problem since the ecu controlls everything .
life sucks !!!!!!!!!!
Old Oct 8th, 2004, 12:18 AM   #12 (permalink)
niky
Doodeee doodee doodee doo
niky's Avatar
timing is not your biggest problem, fuel management is... post what parts you've got and maybe chimmike can help you decide what else to get if you still want to go through with this.
Bigbigcar.com
My new hobby... driving.
Ford Lynx RS / Mazda Protege MP3: Slow but Furious out of the box. :D
niky is offline   Reply With Quote
Old Oct 8th, 2004, 02:39 PM   #13 (permalink)
chimmike
chimmike's Avatar
this is why I never tell any newbie to gather the parts themselves.
also, he may be the "turbo expert" but if he has no experience with the QG, he's not an expert. He says swap to the SR20DET because he'll make more money off you that way.
Old Oct 30th, 2004, 12:33 PM   #14 (permalink)
pedro9474
pedro9474's Avatar
Send a message via MSN to pedro9474
Smile
Mike its good too see such people as yourself on the forums like this with plenty of Knowledge every little bit of information is a help top job mate ...
i have had a good look on your web page at the info listed and i must say thanx mate cause i have'nt been able too find very much info on the QG18DE engines and it makes for a very interesting read ...
At least i know who i'll be contacting if i decide too go turbo with the primera lol
Black Nissan Primera P11-144 1.8s
pedro9474 is offline   Reply With Quote
Old Oct 30th, 2004, 01:18 PM   #15 (permalink)
chimmike
chimmike's Avatar
no problem buddy. I've got a customer over in the UK actually. He's got some great power out of his QG18DE powered turbo Almera
200sx turbo problem - any helpers? Plew Forced Induction & Nitrous Oxide 13 Apr 22nd, 2007 08:00 PM
Turbocharged 200SX SE Triple_T B14 95-99 chassis 32 Mar 10th, 2005 04:02 PM
sr20det turbo SirRacer Forced Induction & Nitrous Oxide 2 Jan 1st, 2004 06:08 PM
What turbo do I have???? zenjoe Forced Induction & Nitrous Oxide 2 Mar 16th, 2003 10:09 PM
